- Jan 7, 2004
- 9,031
- 36
- 91
vsync + triple buffering in WoW, no vsync in Crysis, and IIRC OpenGL doesn't support triple buffering, so only vsync in Q4.
Originally posted by: Aikouka
Originally posted by: NitroTurtle
Thanks again for your review. It's been impossible for me to get any performance data on either card for WoW, as it's never used in any benchmarks. I realize it's not the newest tech, but with the sheer number of people playing the game, you'd think someone would test it. But it seems people think you can max it with a 6800GT, and that's simply not the case once you get into the higher resolutions and settings in a raid environment.
No one tests WoW because it is simply too hard to get a test that is static. The typical lull in framerates that I see in WoW are attributed to the massive amounts of differing data used in Shattrath (tons of different models and skins combined with a massive amount of NPCs and players). Also spell effects, from what I recall on my 8800 GTX, tend to be really bad on my framerate. It was bad enough that I could literally turn away from a brazier and gain 10 FPS even with more people on my screen. It was pretty bad in Hellfire with how the zone has the random fire spurts out of the ground. I remember sometimes when they spit up, my framerate would drop to below 10 (note, this is with two clients open, so it wouldn't be so drastic with only one and that one being full screen, not windowed-maximized).
WoW is pretty taxing on many fronts though... the sheer amount of memory used... the amount of data needing to be transferred off the source (HDD) when switching areas and such.
Originally posted by: BFG10K
Actually what it comes down to is if you want a more robust solution then go single card whether the color is red or green.Originally posted by: ShadowOfMyself
But it comes down to - if you wanna play THOSE games, sure buy an nvidia card, if you wanna play the rest, buy the X2
Actually, you can type /timetest before taking any flight path and it will disable players and NPCs and give a nice performance summary when you land. I know what you mean about the rest of it though. I've built the rest of my machine with that in mind and I can maintain 50-60 FPS even standing in Shattrath with heavy traffic. I'd just like to enable more AA without a performance hit, and really would like to prepare for the shadow system used in WotLK. Both of which will require a faster video card that my 8800.
After reading all of this, I'm really starting to change my mind and lean toward the 280GTX now. It's cheaper and doesn't have any of the problems associated with the dual card/GPU setup.
Originally posted by: Compddd
Why do people keep saying free 8xAA? My FPS drops by atleast 10 or more going from 4xAA to 8xAA on my 4870.
Originally posted by: sourthings
I'm in the wotlk beta, and have a 4870x2, with the new shadows enabled on their highest level, it costs me about 5-7fps depending on the area I'm in. In most areas I'm maxed at 60fps, riding through the woods in places like the fjord/dragonblight, I average around 45 or so. This is at 1920x1200. If all you do is play WoW, I wouldn't bother with multi-gpu as scaling in wow with multi-gpu is terrible. Get a 280 or wait for the 1GB memory version of the 4870.
If you like to play with high levels of AA, as in 8XAA, it's worth remembering that you get 8XAA on an ATI card with no performance hit compared to 4XAA. I don't know if the method used to bench wow in this thread was using the ATI cards free AA or not, looking at the results, looks to me like it wasn't.
You have to use edge-detect filtering and set your AA level to 4 in your game.
Originally posted by: MarcVenice
Otherwise you're running 16x AA, which I don't think is free![]()
YUP!
YUP!
No, if you set in game AA to 4x in WoW, you're running 4xAA regardless of what you set in CCC. You have to to select 'application' in the CCC, and choosing box or edge detect makes no difference.
This is a common problem with CCC, if you have an AA level set in game and then force an AA level through CCC, you usually end up with no AA in the game whatsoever. You can try to set your filtering to edge detect and 4x through the CCC and set your AA choice in wow to 1xAA. For free 8XAA with CCC you set filtering to edge detect in CCC and disable a set AA setting.
This is with adaptive disabled for my rough estimates of frames I'm getting. WotLK seems more intensive than TBC was. Not sure if others notice this but comparing my frames in original wow to TBC, TBC they definitely are lower, and now they're looking lower still in Wrath.
Would be nice if multi-gpu scaling worked for wow as from the frames I see now, it looks that it would be close to maxing wow in most areas at high res with proper multi-gpu scaling.
I bought a EVGA GTX 280 today to play around with. What's the best AA setting to use on 280 nitromullet? The nvidia control panel confuses the hell out of me.
are you running dynamic shadows at "/console extShadowQuality 6"
pretty sure there's going to be a bigger hit than just 5-7 FPS switching from a setting of 0 (no dynamic shadows) to 6 (highest level of dynamic shadows in WotLK)
I believe Blizzard has said that 5 and 6 are only for internal testing. I'm going to assume he's talking about 4, and if so that's a dramatic difference from my current setup. Right now, if I run with shadows at 4, I drop to freeze-frame mode. It says I'm at 5fps, but there's no way that's correct as it pauses for at least a second between frames. However, it has only been like this since the last patch 8820, so if you haven't tested lately maybe that's the reason.
Regardless, I really appreciate the input guys. Since I'm really just looking for the best card for WoW, it helps to get as much information as possible from people actually playing the game.
What is your guys opinions on removing stock coolers and redoing the thermal stuff with AS5? How much will it help?
I'll definitely give that a shot...
You really should be running with ADAA in every game that you can for the price you paid for your card. WoW also looks way better IMO with 4xADAA than it does with just straight 8xAA. It looks really good with 8xADAA, but it's not smooth enough to play. If I can get the edge detect mode to work, maybe that will change.
Whoa! 1 spf with shaodws in WoW on an 8800GTS...? That isn't good news at all. You are running WoW in a maximized window, correct? I wonder if that has something to do with it...
Yeah the card was pricey :/ I use adaptive when I can, it really makes the foliage look nice in wow I find, but it's a noticeable frame rate hit, so I generally avoid it. I should try comparing some frame rate settings with it on.
