Tempered81
- Jan 29, 2007
- 6,374
- 1
- 81
benchmarks and more pics: (it's longer than a 4870x2!)
http://www.xtremesystems.org/f...howthread.php?t=206180
Originally posted by: MarcVenice
So it should cost roughly what TWO hd4850 1gb cards cost? $400 is prolly about right, that'll be 340 euro's or so, which is about right compared to a HD4870 X2 at 420 euro's ... To bad it needs 6pin and 8pin ... I only got 2x6 pin -_-
http://www.behardware.com/arti...tors-the-3rd-wave.htmlOriginally posted by: SunnyD
LCDs cause this mystical input lag too, however they are the preferred display type these days. Makes me wonder, has this input lag thing been tested on CRTs by anyone credible?
Because the resources that are provided will never be utilized as well as a single card?s resources will. That and the extra resources can be a hindrance rather than an advantage.No, I'm not. How is something that provides more resources considered LESS robust?
A few exceptions? What are you basing this on? Some reviews showing 10 or 15 games which is a drop in the bucket compared to the volume of titles out there?Again, as I said, save for the very FEW exceptions, how many of those profile-less titles actually suffer in raw performance on a multi-gpu solution?
The results of running a game without a profile on a multi-GPU system are unpredictable. If you?re lucky the game runs the same as it does on one card which means you get half the performance of your investment. At worst, much worse can happen.
Additionally, just because a game has a profile there?s no guarantee performance and/or compatibility will be at the expected level.
I think you have the mistaken impression reviews showing 10 or 15 games with pretty graphs means multi-GPU is an acceptable solution; in reality there are far more things to consider.
There are hundreds of games out there (if not thousands) that have no profiles. And what about those games that might scale properly but don't render properly due to multi-GPU issues?
