toyota
what? 39-44 is a 13% gain
I think you're misinterpreting the numbers (or maybe I am). How I see it, the "oc'd" and "stock" values that you quoted are BOTH with the 3GHz CPU. The ones in the very first post in this thread are both with the CPU at stock. Both sets of data have 39/44 as the min FPS.
Don't mind toyota. He thinks CPU makes huge difference at GPU limited situations. He thought Crysis would run high setting on 8600gt if he has faster CPU.
there you go again with your lying BS, trolling and usual flamebaiting but everybody already knows what kind of person you are.
my comment to him was based on his own graph. go back and read his post because it does look like he had a gain from oc on the cpu but its hard to really tell exactly what he is saying.
I'm just quoting what you said. I can search the thread where you said that if you'd like. :laugh:
you already tried that over on techreport and you know that wasnt exactly what I said. we can also show that real mature pm that you sent me that is real though.
now back on topic I never said anything about his cpu and this game other than to question his graph.
Oh really? This is what you said about 8600gt playing crysis high detail..
high settings for non core2 cpu users? NO. medium settings at 1024x768 is playable until after the core level then its all low for the snow and carrier levels. with a good core2 duo you could probably put most of the settings on high at 1024x768. regardless of what people "think" Crysis is very cpu demanding below 1280x1024.
You want some more?
IT IS CPU LIMITED AT 1280X1024 OR BELOW. your own link shows that a fast core2 cpu will nearly DOUBLE the framerate over an AMD cpu at 1024x768. below 1280 with my comp I would get a bigger increase in fps by going with a fast core2 cpu than going with a faster card and thats a fact. I used an 8800gt for two weeks and it only made 5 fps difference(from 31 to 36fps) at 1024 over my 8600gt.
I was saying that at 1024x768 a core 2 duo would help if you wanted to turn some settings up and I wasnt meaning with just using an 8600gt. a better cpu at 1024x768 would help but of course not much with an 8600gt.
