Weird. Today after Crysis 3 max temp was 89c. Yesterday was 100C. Can somebody explain why?
is everything you touch broken? I have never seen one person start so many threads about problems. at least this time its not one of your dozens of gpu threads. it seems like you buy something new literally every other week and have issues with it.
and for those that dont know, he has had multiple accounts on multiple forums because he gets perma banned all the time.
that said, buy a proper cpu cooler.
I have a question . If on STOCK cooler i am getting 100c ( with closed case ) in crysis 3 can i rma just my cpu with box cooler?
Given the OP's posting history why is anyone bothering with this. 11 different cards since joining, all with problems that he felt needed a RMA. Numerous threads about cpu temps. He really needs a console or a new hobby. He just got banned at Hard|Forums, I'm shocked. On a side note I've been using the stock cooler for my 4790 and the highest temps I've seen in FC4 and the Witcher 3 is 70.
All of them. Equal opportunity RMA'er.what brand of cards does he buy?
Yep. You should probably RMA the motherboard as it might me helping misreport, the RAM in case they're radiating heat on to the CPU, the GPU in case it's causing an IRQ issue affecting temperature reporting, your hard drives because they might have a virus that reports your temperature high, and your computer case because it isn't helping with airflow.
Then, buy an XBox.
This had me rofl!
OP that's not normal, should average 70s under load, not 100! get a decent aftermarket cooler and end of story. Also, buy a tube of Arctic silver 5 or noctua's offering & use that thermal paste instead.
Then, buy an XBox.
sure why not as you rma everything else...I have a question . If on STOCK cooler i am getting 100c ( with closed case ) in crysis 3 can i rma just my cpu with box cooler?
I have lost count on his his various forum names across multiple forums but his threads are easy to spot.Given the OP's posting history why is anyone bothering with this. 11 different cards since joining, all with problems that he felt needed a RMA. Numerous threads about cpu temps. He really needs a console or a new hobby. He just got banned at Hard|Forums, I'm shocked. On a side note I've been using the stock cooler for my 4790 and the highest temps I've seen in FC4 and the Witcher 3 is 70.
