44Minutes on FX at 8pm EST. - bankrobbery gone wrong
Originally posted by: Mookow
Originally posted by: MachFive
Ah Christ:
Officer (in the gun shop): I can't believe they just let people buy these.
IF PEOPLE COULDN'T JUST BUY THEM, THEN YOU WOULDN'T HAVE GOTTEN THEM, RETARD.
Too bad the shop didnt have anything like, say, an AR-50 or something from Barrett's fine line of 50BMG rifles. Body armor, no body armor... it doesnt matter. Of course, the cops probably couldnt hit them with it, but...
how bout a SAW?? i betcha i coulda hit them with a SAW
MIKE
These guys seem to be hitting a lot of the ocps on their shoulders, the sides of legs, and sides of arms. I think they forgot to check their sites.
Ah Christ:
MIKE
Hit them, easy... head shot? maybe
BTW, did one of the AKs really jam?
Well, even single shot AKs arent too accurate
Did I miss the part where the dye explodes on them when they left the bank? Or did they not even get the money bag out ?
Ah Christ:
MIKE
im just saying hit them period, i dont think kevlar would stop a SAW. and yes, it did jam, i believe those weapons used to jam easy.
MIKE
(and yes you did rh71)
Ah Christ:
MIKE
MIKE
a.) The SAW may or my not penetrate the body armor, it depends on what type armor they are using, what ammo you are firing, and range to target
b.) AKs are known for being flat out reliable. M-16s used to jam easy, not AKs
you missed it
thank you atot resident gun expert, im only a 17 y.o. kid saying what i thought i remembered. (i aint saying that badly, just a thanks, that doesnt sound right per your reply)
and i guessed right on that no armor on the foot!!!
i dont think that kid was necessary for the mobie, without him, it still would have been good, he didnt add much to it. (the kid they arrested)
MIKE
MIKE
I hope you dont think I was being a dick about, I was just correcting you (civilly, IMO)
Actually, some of them are quite accurate. I've seen ones that, bench-fired, maybe 10 to 15 percent worse accuracy than a M4, and they were by no means spring chickens.
A GOOD AK47 is truly a treasure, it's just a matter of sifting through all the cheaply manufactured ones to find a good one.
If you are ebnch firing a AK, its probably a relatively accurate AK.
So, "on average, an AK in semi auto isnt too accurate"
What' wrong with people saying "machinegun". I'm not watching it, but what percent of southern californians do you think would refer to an M-16 or AK-47 as a machinegun? I'd bet at least half.
Yeah. I didn't watch it either, but while it may not be technically accurate, I'd bet it wasn't too far from the actual dialogue at the time.
Rob
And that half would be wrong.
If something's incorrect, you should strive to correct it.
Just like clips. Almost no gun has used a "clip" for decades. They're called magazines. If that's too many syllabels, say "mags," but DON'T say clips. This isn't an M1 Garand.
it's awesome! one of the best shootout movie i've ever seen, of course Heat and Ronin top my chart 🙂
