3DMARK 2001
I thought the statue scene looked pretty bad... (i ran it in the default 640X480... maybe I should run it higher). I do have to say that the Matrix scene is AWESOME with the reflections!!!!!
I had no trouble with the statue, but I had no sound in the demo until the credits...strange... And why does it run the nature part in the demo, but not in the benchmark?? The only tests I could do were 4(nature) and the pixel shader.
With P3 700E and Radeon VIVO 64 DDR at default in w2k(3102 drivers)
2543
with 933EB and Radeon at 200/400
3152
ooops, yes, my mistake....
what is it with the sound bug? anyone hearing sound in the demo (not only when the credits roll)
I heard sound the through the entire demo....
Wow... relic..your scores in win2k are REALLY high... and that is weird since you have an ATI card! I'm gonna try OCing some more.. and see how high I get....
Yeah.. in my Radeon tweaker there is a checkbox for "Enable pixel shaders in hardware" and 3Dmark still won't run test #4.
i ran the default benchmark with no trouble at all with the 7089 driver for the radeon. i got score of 3033 with WinME.haven't tried the demo yet
Update:
I actually didn't have Powerstrip on, so it was running @148/148. When OCed to 183/183, I actually got 3000. I am going to try 200/200 later on tonight and see how it does. (I'll see if I can get as fast as Relic did with his Radeon 64MB VIVO @200/200.
its all about eye candy....installed various driver sets and still cant get the per pixel water test to run on my GTS....whats up with that? the GTS can do per pixel shading..afterall it was advertised by nvidia as the worlds first per pixel shading GPU aka NSR
Is anyone having problems besides me? At first I couldn't even see any of the sequences so I installed the official ATI drivers and then everything was fine. But during the demo, at the end of the earth zoom sequence it just freezes. Music plays on my the computer doesn't respond and the screen is just stuck at the earth. Help!
I've tested on my rig🙂
3DMARK2001 PROJECT FILE
PROJECT
Name Benchmark #1
Description
Registration Name
Registration Key
3DMark Version 200
DISPLAY
Platform NVIDIA GeForce2 Ultra
CPU Optimization D3D Hardware T&L
Width 1024
Height 768
Depth 32 bit
Z-Buffering 24 bit
Texture Format Compressed
Buffering Triple
Refresh Rate Default
FSAA Mode None
OPTIONS
Show Title Screens Yes
Continuous Benchmark No
Benchmark Run Count 1
Demo Sounds Enabled Yes
Continuous Demo No
Game Sound Effects Enabled Yes
Game Music Enabled Yes
Game Detail Level High
RESULTS
3DMark Score 3689
Game 1 - Car Chase - Low Detail 75.1 fps
Game 1 - Car Chase - High Detail 24.9 fps
Game 2 - Dragothic - Low Detail 57.6 fps
Game 2 - Dragothic - High Detail 19.6 fps
Game 3 - Lobby - Low Detail 74.3 fps
Game 3 - Lobby - High Detail 36.5 fps
Game 4 - Nature Not supported by hardware
Fill Rate (Single-Texturing) 401.7 MTexels/s
Fill Rate (Multi-Texturing) 759.6 MTexels/s
High Polygon Count (1 Light) 13.5 MTriangles/s
High Polygon Count (8 Lights) 4.2 MTriangles/s
Environment Bump Mapping Not supported by hardware
DOT3 Bump Mapping 61.2 fps
Vertex Shader 43.6 fps
Pixel Shader Not supported by hardware
Point Sprites 1.2 MSprites/s
SYSTEM INFO
System Info Version 2.0
Installation ID 0xd4d31c9c
OEM ID
CPU INFO
CENTRAL PROCESSING UNITS
Manufacturer AMD
Family Athlon(tm)
Internal Clock 1.24GHz
Internal Clock Maximum 1.24GHz
External Clock 133MHz
Socket Designation SOCKET A
Type unknown
Upgrade unknown
Capabilities MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!
Version AMD Athlon(TM) Processor
CPUID 0x00000642
CACHES
Level 1
Capacity 128KB
Type Data, Internal
Type Details Synchronous
Error Correction Type unknown
Associativity 4-way Set-Associative
Level 2
Capacity 256KB
Type Data, Internal
Type Details Synchronous, Pipeline Burst
DIRECTX INFO
DirectX Version 8.0
DIRECTDRAW INFO
DirectDraw Version 4.08.00.0400
DISPLAY DEVICES
Description Primary Display Driver
Manufacturer NVIDIA
Name NVIDIA GeForce2 Ultra
Total Local Video Memory 64MB
Total Local Texture Memory 64MB
Total AGP Memory 112MB
Display Driver nvdisp.drv
Display Driver Version 4.12.01.0650
Max Texture Width 2048
Max Texture Height 2048
Max User Clipping Planes 0
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Textures In Single Pass 2
Vertex Shader Version N/A
Pixel Shader Version N/A
Max Vertex Blend Matrices 0
Max Texture Coordinates 8
Device ID 0x0152
Vendor ID 0x10de
Sub-System ID 0x10491102
Revision 0x00a4
DISPLAY MODES
320x200x16-bit RGB [565]
320x240x16-bit RGB [565]
400x300x16-bit RGB [565]
480x360x16-bit RGB [565]
512x384x16-bit RGB [565]
640x400x16-bit RGB [565]
640x480x16-bit RGB [565]
720x480x16-bit RGB [565]
720x576x16-bit RGB [565]
800x600x16-bit RGB [565]
960x720x16-bit RGB [565]
1024x768x16-bit RGB [565]
1152x864x16-bit RGB [565]
1280x720x16-bit RGB [565]
1280x960x16-bit RGB [565]
1280x1024x16-bit RGB [565]
1600x900x16-bit RGB [565]
320x200x32-bit RGB [888]
320x240x32-bit RGB [888]
400x300x32-bit RGB [888]
480x360x32-bit RGB [888]
512x384x32-bit RGB [888]
640x400x32-bit RGB [888]
640x480x32-bit RGB [888]
720x480x32-bit RGB [888]
720x576x32-bit RGB [888]
800x600x32-bit RGB [888]
960x720x32-bit RGB [888]
1024x768x32-bit RGB [888]
1152x864x32-bit RGB [888]
1280x720x32-bit RGB [888]
1280x960x32-bit RGB [888]
1280x1024x32-bit RGB [888]
1600x900x32-bit RGB [888]
TEXTURE FORMATS
32-bit ARGB [8888]
32-bit RGB [888]
16-bit RGB [565]
16-bit RGB [555]
16-bit ARGB [1555]
16-bit ARGB [4444]
FourCC [DXT1]
FourCC [DXT2]
FourCC [DXT3]
FourCC [DXT4]
FourCC [DXT5]
3D Capabilities AGP Texturing, Hardware Transform and Lighting, Positional Lights, Subpixel Accurate Rasterizing, Stencil Buffers, Range Fog, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Rendering to a Window, Mipmap LOD Bias Adjustment, Projected Textures, DXT Compressed Textures
DIRECTSHOW INFO
DirectShow Version 6.03.01.0400
REGISTERED DIRECTSHOW FILTERS
.RAM file Parser
AC3 Parser Filter
AC3 Source Filter
ACELP.net Sipro Lab Audio Decoder
ACM Wrapper
ASF ACM Handler
ASF DIB Handler
ASF DJPEG Handler
ASF ICM Handler
ASF JPEG Handler
ASF URL Handler
ASF embedded stuff Handler
ASX file Parser
ASX v.2 file Parser
AVI Decompressor
AVI Draw
AVI Splitter
AVI/WAV File Source
Color Space Converter
DV Muxer
DV Splitter
DV Video Decoder
Default DirectSound Device
Default MidiOut Device
DivX MPEG-4 MPG Video Decompressor
File Source (Async.)
File Source (Netshow URL)
File Source (URL)
File stream renderer
IVF source filter
Indeo(R) audio software
Indeo® Audio Software
Indeo® Video 4.5 Decompression Filter
Indeo® Video 5.11 Decompression Filter
Internal LMRT Renderer
Internal Script Command Renderer
Line 21 Decoder
Lyric Parser
MIDI Parser
MJPEG Decompressor
MPEG Audio Decoder
MPEG Layer-3 Decoder
MPEG Video Decoder
MPEG-2 Demultiplexer
MPEG-2 Splitter
MPEG-I Stream Splitter
Microsoft MPEG-4 Video Decompressor
Microsoft Screen Video Decompressor
Multi-file Parser
NSC file Parser
NetShow Theater Source Filter
OpenDivX Decoder Filter
Overlay Mixer2
QT Decompressor
QuickTime Movie Parser
SAMI (CC) Parser
TrueMotion 2.0 Decompressor
URL StreamRenderer
VGA 16 Color Ditherer
VIVO Audio Decoder Filter
VIVO Video Decoder Filter
Video Renderer
Voxware MetaSound Audio Decoder
Voxware MetaVoice Audio Decoder
WM ASF Reader
WM ASF Writer
WMP CD Filter
Wave Parser
Windows Media Audio Decoder
Windows Media Multiplexer
Windows Media Update Filter
Windows Media Video Decoder
Windows Media source filter
XML Playlist
MEMORY INFO
Total Physical Memory 510MB
Free Physical Memory 379.25MB
Total Pagefile Memory 325MB
Free Pagefile Memory 238.90MB
MEMORY ARRAYS
Max Module Capacity 1GB
Location System Board
Use System
Supported Error D&C None
Supported Speeds unknown
Supported Types unknown
Supported Voltages unknown
MEMORY SLOTS
Installed & Enabled Size 256MB
Form Factor DIMM
Frequency 0Hz
Slot DIMM 1
Manufacturer
Type DRAM
Enabled Size 256MB
Total Bit Width 72
Data Bit Width 64
Installed & Enabled Size 128MB
Form Factor DIMM
Frequency 0Hz
Slot DIMM 2
Manufacturer
Type DRAM
Enabled Size 128MB
Total Bit Width 72
Data Bit Width 64
Form Factor DIMM
Frequency 0Hz
Slot DIMM 3
Manufacturer
Type DRAM
Enabled Size 128MB
Total Bit Width 72
Data Bit Width 64
MOTHERBOARD INFO
Manufacturer ASUSTeK Computer INC.
Model <A7V133>
Version REV 1.xx
BIOS Vendor Award Software, Inc.
BIOS Version ASUS A7V-133 ACPI BIOS Revision 1004
BIOS Release Date 03/06/2001
BIOS Charasteristics Plug and Play, Flash, AGP
CARD SLOTS
Number 1
Designation PCI 1
Type PCI
Characteristics 5.0V, 3.3V, PME Signal
Data Bus Width 32
Details Available, Long
Device Class unknown
Device Description
Device Revision 0x00000000
Device Manufacturer
Device Driver Date
Number 2
Designation PCI 2
Type PCI
Data Bus Width 32
Details In Use, Long
Device Class Sound, Video or Game Controller
Device Description Creative PC-DVD Encore Dxr3
Device Revision 0x00000002
Device Manufacturer Creative Labs
Device Driver Date 6- 8-1999
Number 3
Designation PCI 3
Type PCI
Data Bus Width 32
Device Description Creative SB Live! Value
Device Revision 0x00000004
Device Driver Date 8-26-1999
Number 4
Designation PCI 4
Type PCI
Data Bus Width 32
Device Description
Device Manufacturer
Device Driver Date
Number 5
Designation PCI 5
Type PCI
Data Bus Width 32
Device Class Network Adapter
Device Description AOpenLAN ALN-325 10/100 Base-TX Fast Ethernet Adapter
Device Revision 0x00000010
Device Manufacturer AOpen Inc.
Device Driver Date 3- 9-1999
Number 0
Designation AGP
Type AGP 4X
Data Bus Width 32
Device Class Display Adapter
Device Description NVIDIA GeForce2 Ultra
Device Revision 0x000000a4
Device Manufacturer NVIDIA
Device Driver Date 12- 4-2000
Number 0
Designation AMR
Type I/O Riser
Data Bus Width 32
Device Description
Device Manufacturer
Device Driver Date
SYSTEM DEVICES
Description VIA Tech Standard CPU to PCI Bridge
Manufacturer VIA
Vendor ID 0x1106
Device ID 0x0305
Subsystem ID 0x80421043
Revision 0x0003
Description VIA Tech CPU to AGP Controller
Manufacturer VIA
Vendor ID 0x1106
Device ID 0x8305
Subsystem ID 0x00000000
Revision 0x0000
Description VIA Tech Standard PCI to ISA Bridge
Manufacturer VIA
Vendor ID 0x1106
Device ID 0x0686
Revision 0x0040
Description VIA Tech Power Management Controller
Manufacturer VIA
Vendor ID 0x1106
Device ID 0x3057
Revision 0x0040
MONITOR INFO
MONITORS
Name ViewSonic E790-3
Manufacturer ViewSonic Corporation
Max Width 1600
Max Height 1200
OPERATING SYSTEM INFO
Operating System Microsoft Windows 98
Version 4.10.1998
Desktop Width 1024
Desktop Height 768
Desktop BPP 32
🙂My Rig🙂
I´m in a hurry now, but I am impressed with my score now. I just had the time to check what others are getting and it seems I have a really great score. This would be first in 3dmark. The &quot;Pixel Shader Mystery&quot;
can be solved: I think they just forgot to mention that they ment PROGRAMMABLE Pixel Shaders. The GF2 and the Radeon support Pixel Shaders, but not programmable ones. This is a GF3 feature. Though I think that their surely is a bug in test 4. Why does it run in the demo(and beautifully I might add) and not in the benchmark.
My sound probs went away in the second try. For info on my system, check my sig. I am using the latest Ati w2k drivers 3102 and I´m using Radeon Tweaker for quality boosting. I will try to get into the online result browser, but this seems to have to wait till the site is accessable again.
