Hey Guys!
I just setup my first Ivy Bridge setup with a 3770k and a AsRock Extreme4
Here is my problem:
I can get the CPU stable at 4.5ghz with 1.160v using fixed mode, it will pass Prime and Cinebench no problems.
When using offset mode at +.005 and Turbo at +.004 @ 4.5ghz (used this as a test base) it also passes Prime and Cinebench @ 1.176v load, BUT when playing games the voltage jumps up/down and even drops below 1.0v. This causes games to Crash To Desktop, Witcher 2 would just quit with no errors. It is stable at idle, and stable at 100% load, but games don't give it 100% load so the voltage is not constant.
How can I use offset mode and keep the voltage range from jumping around like crazy when under a load? I want to use offset mode for the lower voltage/temps on idle.
Here is my problem:
