AlabamaCajun
- Mar 11, 2005
- 126
- 0
- 0
Originally posted by: WhipperSnapper
Is this really a big issue between the Athlon 64 and the Socket 939 Opterons? Isn't the normal bandwidth about 8.0 Gb/s at 800 Mhz FSB? (I might be wrong, forgive my ignorance.) If so, how would you end up getting beyond 14 Gb/second on either chip anyway? Wouldn't you have to increase the FSB far beyond 1000 Mh before the Opteron would have any advantage?
Actually the FSB is normally 1000M unless C&Q is active. Combined memory and io raises it the other 400. I believe it is more in the lab speed as opposed to about 11G in the real world. I'm somewhere in the neighborhood of about 12G with HTT at 1100+. Serious OCers will gain more with the Opterons but for most of the best chip is still the 3700 or 4400X2. If buget minded get a 3200 Venice or 3800X2. The advantage of the 3700 is the next Sandy up is the 4000 and it's near the top of the CPU speed and costs a good bit more for a chip you want to OC. The 3500V and 3700SD get the best cost/OC ratio.
Jack, check with MWave, I think they are a bunch cheaper.
