Suspicious-Teach8788
Originally posted by: Dark Cupcake
Well what i did was get a prog to read the drive from start to finish (used MHDD). Using everest gives similar results.
Thats what i got. (these numbers are using everest, i didn't record the other ones, and it would take about 5 hourst to retest it all)
All drives are sata.
Raptor 74gig - 69mg/sec start - 50mg/sec end - average access 7.38ms (raptors are the 8mg cache versions)
Raptor 36gig - 62mg/sec start - 43mg/sec end - average access 7.69ms
WD 200 gig - 61mg/sec start - 35mg/sec end - average access 13.01ms
WD 200 gig- 59mg/sec start - 34mg/sec end - average access 12.52ms
Seagate 80 gig (7200.9) - 70mg/sec start - 33mg/sec end - average access 14.09ms
Seagate 120 gig (7200.7)- 57mg/sec start - 28mg/sec end - average access 12.44ms
Thats the seagate is slightly faster at the start while the raptor smashes it in access time and reading at the end. I think that segate 80 gigi is a single plater drive, not sure though. In the end the raptor is overall a lot quicker to use.
The 36gig one outperforms the 200 gig wd drives.
If anyone could run the same thing on a 320 gig drive that would be good, just to compare.
As you can see .. Raptors are DEAD (at least the old ones). The 74GB Raptor and the 7200.9 160gb put up a pretty good fight, but I have to say the Seagate won simply because its cheap and fast.
I think you should be using HDTune or maybe HDTach, but I think your nubmers might be low? I dunno.
My 7200.9 250gb averages 55 - 56 MB/sec for transfers
Raptor 74GB ADFD (16mb ones) averages 75 MB/sec
My 7200.10 320gbs averages 65 / 66 (1 is faster due to firmware)
Umm, AFAIK, my 7200.10 starts around 80mb/sec in the sequential transfer tests.
There's no reason to get a 36GB Raptor if Dark Cupcake's benches are correct. My 74GB Raptor is fast only because its an ADFD one. I would not have bought a Raptor if it was the GD series (old 8mb ones) given that I have 7200.10s in RAID-0.
