OS
- Oct 11, 1999
- 15,581
- 1
- 76
Originally posted by: DivideBYZero
Originally posted by: OS
Originally posted by: Vic
I don't doubt that. My point was that you're gonna to spending just as much if not more money, and pushing reliability just as far if not further to its limit, to get 400whp out of a 350Z as to get it out of an STi.Originally posted by: OS
They make bolt on SC/turbo kits for VQ cars, ~5Gs, a little below 400 WHP.Originally posted by: Vic
The STi is significantly superior to the 350Z. So much so I'm not even sure where to begin. For starters, the STi seats 4 comfortably and has such novelties as a glovebox. For another, you can drive it more than 6 months out of the year. As to safe reliable power, you can pretty easily 400whp out of STi safely and reliably, and still keep it as a daily driver. To do so, I would recommend a TBE, larger turbo, FMIC, and ECU reflash or piggyback plus dyno tune. Still, I would argue that it's harder to get 400whp out of a 350Z than out of an STi.
I am answering the OP's original question.
IMO only marginally so, since all that stuff you listed isn't cheap. And not necessarily less reliable, i know someone with a bolt on SC VQ, everything else stock down to clutch. Daily beaten, ~30K miles and dead reliable.
FMIC, turbo and a remap not reliable? How? Leave a hose off the turbine? Not tighten a hose on the cooler hoses?
It's very tried and tested in the Subaru world, the car comes with forced induction, the 350z does not. End of discussion.
Don't pevert what I said and read everything else before it.
