Gamingphreek
- Mar 31, 2003
- 11,679
- 0
- 81
Originally posted by: Dark Cupcake
Originally posted by: Gamingphreek
Sure it isn't a problem but it is horrible design/engineering. That much heat means a ton of power is being used. Given that it is a 4870 and isn't the fastest thing on the planet, it shouldn't be wasting that much power (be it by Transistor Leakage or otherwise).
-Kevin
Temperature is not equal to power consumption. Sticking a masive heatsink on it and limiting it to 30C will not make it consume significantly less power. (In reality there should be a slight difference due to semiconductor properties, if I remember correctly)
On the other hand the original 4870 512 card I had used to idle at 82C and load during heavy gaming to 86C. I don't see that as a bad thing, since the thermal stress on the chip will be much lower.
Also while a 4870 should be able to run Furmark, I wouldn't do it for extended periods of time as the vrm get insanely hot (my msi card stable but 120C on them, sapphire one doesn't have temp monitoring for them, it might be similar design to palit cards).
Temperature is not linear to power consumption, but heat is produced as one of the side effects of power usage. The Law of Conservation of Energy states that energy can neither be created or destroyed - here is a prime example of electrical energy being converted to heat energy.
Additionally, slapping a heatsink on it affects the independent variable which is the heat produced given a supply of power - thus you can't use that as a counter example
The VRM's are generally cooled enough, the core and the memory are the main things that need active cooling.
-Kevin
