Originally posted by: milleron
Originally posted by: Grimreaper23
I tought the zalman was better? IOs that the tower looking one if so what fan should I put on there.Originally posted by: theman
get a thermalright xp-120 instead of the zalman. get 2.9ghz.![]()
Most serious overclockers opt for a 120mm Panaflo, but it doesn't have RPM monitoring if that's important to you. If it is, consider AcoustiFan or a Thermaltake Thunderblade. The latter is rated at a very quiet 19 db, but who knows how they tested it? Sleeve-bearing fans are a little quieter. Ball-bearing fans are a little more reliable. The Panaflo has neither type and uses something like the liquid bearings you find in better hard drives. Get the Panaflo unless your motherboard won't POST without detecting a spinning CPU fan.
I agree with bjc112 that the XP120 is the best heatsink for A64s, but the Zalmans are right there, too. I just don't like their extreme weight -- not good for someone who wants to move the computer much.
XP120 with a panaflo 120mm has better cooling than the Zalmans, however an XP-90C Copper with a 92mm panaflo will cool better than both XP120 / Panaflo 120mm and the Zalmans.
I know a guy who has that combo and yes it cools awesome, however after a few weeks he pulled the tornado fan out of his comp and threw it against the wall because it gave him migraines on a daily basis, couldn't sleep at nights, etc. *shiver*
