3 TB HD problem
irse
185
I bought a 3 TB HD and installed it into my computer but only can use 1.99 TB and 742 GB is unallocated and I can't get it to do anything. Is it a motherboard problem? Motherboard and processor is in my sig. Thanks
Elixer
10,371
762
Either reformat the HD, or just make multiple partitions.
IMO, multiple partitions is much better on a big drive, so you can back everything up much easier / faster.
Carson Dyle
8,173
524
How is it either faster or easier?
irse
185
Insert_Nickname
4,971
1,696
I've got the latest bios and drivers. In disk management, the unallocated partitions is grayed out and I can't even partition it or reformat it.
You need to remove ALL partitions before you can convert it... ;)
Right click on disk -> Convert to GPT-disk
Elixer
10,371
762
If you have multiple partitions, it takes much less time to backup the actively used partition, than it does the whole HD.
ie, game partition, data partition, and apps partition, while you wouldn't really care about the games or apps, since you can install those again without too much trouble, the data partition is where you actively use/store things, so it would take much less time to backup that partition than doing the whole drive.
Carson Dyle
8,173
524
I still don't understand. Unless you're talking about using imaging to do backups. If you have 1/4 TB of files to backup, whether they're spread across one or five partitions, it should take about the same time.
Elixer
10,371
762
Yeah, images, should have clarified.
ch33zw1z
39,838
20,433
How you organize your drives is up to you, moving x amount of data is still moving x amount of data.
The only drives I have with multiple partitions are my boot drives. My data drives are one big partition. I have 2TB and 1.5TB data drives.
