I got a Zalman CNPS8700 LED that I just remounted to a new motherboard, but the motherboard only support PWM, so my fan runs at full speed unless I use a manual voltage adjuster.
I found this converter for 3 pin to 4 pin PWM, but it seems the company has went out of business. Does someone else make one like it?
Nanoxia PWMX 3-Pin to 4-Pin PWM Converter/Fan Speed Controller
http://www.svc.com/pwmx.html
Is there a fan that I can get to replace the one on the heat sink that support 4 pin PWM?
Thanks.
Thanks.
