Jeff7181
- Aug 21, 2002
- 18,368
- 11
- 81
Originally posted by: Duvie
Originally posted by: Jeff7181
Originally posted by: Sentential
While this appears to look all well and good there is something you arent seeing. The reason why Venice and others are scaling so nicely, and why there is a 3ghz A64 on the horizon, is because they are lengthening the pipeline much like Intel did with prescott.
Granted not drastically but be aware, you are not getting what you think you really are. They will not be as fast clock-per-clock as the orginal design would have been. If anything they will be the same speed with SSE3 to make up for the shortcomings.
If you want proof go read the A64 article on the front page. AMD rep says such clear as day: "AMD *will* be increasing the pipeline stage to increase CPU speed"
How would you know?
Yeah, amd said they will, but that doesn't mean they have (seeing as rev E is already out in the form of the opteron 252s.)
Ive long suspected that E0 use a relaxed pipe. All signs from what I have seen point to it (this was before I went to intel, all fanboism aside). Here is what we know:
#1) Almost no difference in speed on SuperPI and in benches between them.. like 0%
#2) Higher heat. 67W --> 84W (whincester vs venice)
No one has come up with an explination to this... I cant either other than they legthened the pipeline for 3ghz which was recentally announced
That's pure speculation for now. Yes they said they will, but I think they were referring to the next major model change... the successor to the Athlon-64.
The "higher heat" could be the specification for the Venice core, not a specific model. If Venice scales to 3 GHz, of course it'll put out more heat than a 2.4 GHz Winchester. That doesn't mean that the Vencie core uses more power than a Winchester if clock speeds and voltage are the same.
Exactly....There is no logic in his thought!!!
There's also no reason to believe AMD would want to lengthen the pipeline at this point. FX-55's scaling to 3 GHz is proof that the pipeline is good up to 3 GHz and probably beyond before it HAS to be lengthened to go any further.
Also, the tests being done in that other thread show that the Venice performs slightly better than a Winchester at the same speed... the opposite should be true if the pipeline has been lengthened.
