3.0 Shader
uOpt
1,628
Originally posted by: Jeff7181
Some of the bridge areas are a bit too bright... and the overall brightness DOES adjust when you move from dark to light areas just like your eyes do. The only problem is when you move into a dark area and look back at a bright area, it doesn't adjust... you have to move back into a specified "zone" for the levels to adjust.
Sorry, that is with HDR? Non-HDR doesn't adjust, right?
uOpt
1,628
Originally posted by: slash196
Silly me, I thought the second one looked better...
What did you like better about it?
I know some people like to have a nice bright screen where they can see into all the shadows... I don't... not being able to see in shadows is a step towards realism. ;)
I have my monitors for coding pretty dark so the first one was too dark for me.
But I get the point now.
Jeff7181
18,368
11
Correct.
nitromullet
9,031
36
I wish they would allow the intensity to be changed... sometimes it's just too much... maybe a 1.4 patch will do it...
Agreed, HDR gets on my nerves in the indoor levels. Even the smallest light or simply white objects are blinding. Not very realisitc IMO.
Jeff7181
18,368
11
They either need to turn down the intensity, or have the intensity level change faster depending on where you're looking, not where you're standing.
caz67
1,369
It's the way of the gaming future. It's foolish IMO, to buy a card that doesn't support PS3.0
Pete
4,953
From what I hear, what you're seeing in FC 1.3 is more of a bloom effect than HDR. At least, I don't see much more than a difference in brightness between the two shots, not Higher Dynamic Range. Both the darks and the lights look darker, rather than the darks looking darker and the lights, lighter.
