Question 2nd 2080 ti running on x8
manish_mv
PLEASE HELP ME /\
I have x399 MSI carbon mobo
4 slots x16 x8 x16 x8
3 cards gtx660 and 2 2080 ti
both 2080ti are installed on x16 ports but still one on the second x 16 port tells card running on x 8 speed as per GPUZ.
Why ? What is wrong i am doing?
Regards
Manish
manish_mv
Dear mxnerd
Thanks for the reply. Yes I am using the E1 and E4 slots already but still the same problem. Image attached.
manish_mv
Sorry 4 late reply dear. Yes I have swapped them whatever card is there on E4 lane is showing running on x8. The CPU is TR 1950x it has 3.0 64 lanes.
I am really frustrated.
However there is one thing i noted. Could the reason be Power saving feature of any kind? Pls refer the attachmentsScreenshot_2.jpgScreenshot_3.jpg
mxnerd
6,799
1,103
1950x has 60 PCIe lanes but should be able to support at least 2 x16.
If you suspect power saving affects the speed, why not change the power plan to high performance and see?
Also try to contact MSI support or join MSI forum.
manish_mv
Please tell me how to do change power mode. Secondly updating bios i wud not prefer that because that will kill the sata raid0 i done
aigomorla
21,067
3,575
Do you have a nVME?
Sometimes they eat pci-e lanes and will make slot 1 into an 8x.
Wait you have 3 video cards?
That is your problem, you populated all your slots, and its making your 16x run at 8x.
60 lanes total means that Total.
You board will use up lanes for things like nVME, Wifi, and other on board stuff.
60 lanes does not mean you have all 60 lanes to just the PCI-E.
Remove all the NVME's you have minus the one located where slot 2 is.
Remove the 660GTX.
Recheck to see if the board will now run the 2 slots in 16x.
I think your 660GTX is forcing your bottom 16x to run in 8x, or a nVME in Slot5 if u have one there.
mxnerd
6,799
1,103
BIOS update will kill your SATA RAID 0? Really? Even if the BIOS probably will be reset after the update, all you need is a simple reconfiguration.
And as what aigomorla has said, it could be that your 660GTX and nVMe (if you have any) are making 2nd 2080ti running at 8x.
manish_mv
Dear All
I removed the gtx 660 but still it is showing running at 8x in bios (attached) and GPU-Z. Really frustrating
There is no nvme HDDs all other pcie slots are vacant. The Raid which I have setup is SATA raid using 2 Samsung SSDs. In the later bios versions sata raid is removed so it doesnot support raids anymore but i have not checked the very later ones.
Regards
Manish
mxnerd
6,799
1,103
Like I said, contact MSI support or join MSI forum. You will get your answer faster.
manish_mv
Later I realised that my PCI Express power connector is not connected and it is vacant now I connected it with PCI e power cables coming from the power supply and I was very much hopeful this time that yes I think this is the problem and when I turn on my PC it still shows running at X8.
I did posted this problem in MSI forum also but I I have not gotten any reply till yet.
I think I have to physically take it to MSI service centre.
