I like this guy's way of thinking!Originally posted by: GnomeCop
its a waste, but hell this is America, go for it
Originally posted by: bill_n_opus
Originally posted by: MasterHoss
:Q 2GB???!!??
Originally posted by: nick 1985
give me some money
Originally posted by: mechBgon
Not necessarily... see the situation I described above. Total memory usage usually doesn't top 300Mb at any time, but without the other 1200Mb in there, I couldn't do zero-disk-activity Office2000 installs.Originally posted by: ElFenix
why don't you look at the task manager for how much memory you're using. if you're using less than 1 GiB you're not going to get any benefit going from 1 GiB to 2 GiB.
Originally posted by: shuttleteam
I find that 4GB is not enough.
2GB is hardly overkill. It's all in what you use your system for. If you're just surfin' and postin' and doin' a little 3DMarkin', then it's akin to renting a 24' Ryder truck to return a handful of library books...
-DAK-
There's no such thing as a zero-disk activity install. EVERY program has to write to the disk. If that didn't happen then the minute you reboot your installation would be gone because it would still reside in the memory.
You're right in what you say, but you misunderstood what I said.Originally posted by: NokiaDude
Originally posted by: GaryShandling
Theres no such thing as overkill in the computer industry, it doesnt take alot of intelligence to realise that. Time eventually will make your system obsolete, but having better products in your comp will mean it will take less time and give you better performance at the later stages.
-DAK-
Originally posted by: Chaotic42
I would go for it. I've got a lame stick of 512 now, and I can tell the difference in going from 1280->768. My next system will have 4GB, at least.
-DAK-
What the heck are you running?? Must be a server or something like that.
Yeah, at least....
Tell me what the hell you are doing to need at least 4 gigs of ram, hosting the entire internet?
-DAK-
Thats what I was going to ask had you not posted that. It seems like Shuttle team has been working on some very exquisite systems because if you read over his previous posts, he mentions systems we never even think about. One of them was of a ton of hard drives spinning up, thats sounded like an engine!
Yeah, at least....
Workstation actually. Linear Aerospike RTS generates enormous amounts of data. This must be analysed. The process takes a while...
-DAK-
