Zap
Originally posted by: ghost recon88
better than a HD3850? Yes hands down better!
Okay, for $141 shipped after rebate, I might be in...
Originally posted by: JoLLyRoGer
Originally posted by: KingThot
Originally posted by: JoeyM
Newegg has this for $140 AR ($15)
That's a 256-bit, about 5% slower and not flashable to XT.
Good luck to all who ordered through eWiz. My order was canceled last night.
Mine too... 🙁 They said eWiz listed the cards 512 bit version by mistake but in actuality they were 256's. But hey, at least they were up front about their mistake and did the right thing... I'd have been pissed if they had shipped and I'd actually gotten a 256 bit card after paying for the 512 and then having to go though the hassle of an RMA and re-shipping, waiting for my refund, etc. etc...
Well, mine shipped and is supposed to get here on Thursday. If it's 256-bit and not 512-bit, then it's going back to ewiz :-( I'll update you guys when I get it.
To: xxxxxxxx@hotmail.com
Subject: eWiz order: E297XXX
Date: Fri, 25 Jan 2008 16:18:51 -0800
Dear JR,
I just got an update from our warehouse. Apparently we got 1 last piece of the card you wanted, AT-29PRO51 in stock. This is the 512 memory interface one that was originally ordered.
Please let me know if you would still like this order. We can honor the lower pricing ($169.49) on it.
Xxxx Xxxx
eWiz.com
408-934-2500
Return Policies
This item is covered by Newegg.com's Standard Return Policy.
* Return for refund within: 30 days
* Return for replacement within: 1 year
Originally posted by: Zap
I ended up passing on this because of the rebate plus higher power usage. I ordered two 3870 cards from Micro Center (see other deal) for just under $400 shipped.
I received the car from ewiz today. I can't find anything except the packing list that states it's 512-bit. It looks exactly like the 256-bit card on Newegg except that it has an 8-pin and a 6-pin power connector. Can someone help me verify this before I install it?
Thanks!
Originally posted by: kmmatney
I bought one yesterday. I almost bought a HD3870, but then decided that this was a better deal at $134 AR. I heard the 256 vs. 512 bit shouldn't make much difference - at least I hope it wont. I plan on overclocking it some to get performance greater than at least HD3850 levels. I really wanted to stay around the $150 mark, and this looks like the best bang-for-buck at that price price,.
Thanks!
Yours is Sapphire?
on the Green label with the P/N and SKU is written HD2900PRO 512M 256-BIT
also on the Card itself, on the bottom - also a green label - say "256-bit"
--and on the front of the box it has "256-bit edition" pretty plainly written
---on TOP of that, mine has only *one* 8 pin pciE power connector [my XT has 1-8 and 1-6 pin] :Q
---there is no question, *mine* is 256-bit 😛
what resolution do you run at?
starting at but especially over 16x10, you would appreciate 512-bit over 256 - especially IF you try to add AA.
--below 16x10, it is a fairly small performance hit ... a couple of percentage points, afaik. IF you can OC it to XT speeds you will have a pretty fast card ... closer to 3870 speeds than 3850.
This is my "2nd" card ... for CrossFire. My MB has 1-pciE X16 for my 2900xt and a pciE X4 slot for my new Pro. The bandwidth is limited by the 4x express lane ~10 to 25% so the Pro shouldn't be too much slower than another XT
- that is, IF i can get the clockspeed to match my XT. If so, there will be no penalty.
[doubtful - *Both* GPUs in X-fire must run at the slower of the two speeds if there is a mismatch ... so i want to get the Pro as hi as she will go]
Dual channel interconnect is not required for ATI CrossFire, and may not be included in all product configurations
I'm not sure what the answer is to your last question, but I did receive the crossfire bridge interconnect with mine.
