Klunt Bumskrint
Is that the same socket?
Yes it should be the same socket, but make sure that you bios is updated if you're using any of the older chipsets.
Herp derp. No, 3930K isn't the same socket as 2500K. 3930K needs an LGA2011 motherboard. And no, it wouldn't benefit the OP's gaming performance in the least.
My suggestion: buy your grandma a new pair of disco pants.
Sup dudes, I've got the money and the itch to upgrade my CPU but I'm stuck between the i7 2700k or the i7 3770k.
The rest of my system is fine and I have an ivy ready z68. I like clocking at 4.5GHz and I am not a fan of heat.
Is ivy worth the extra? The Anandtech benches seem about even.
If your not a fan of heat, stay away from Ivy Bridge if your going to OC.
Pick up the 2700k Sandy much cooler chip, and a better OCer you can get 5Ghz with this. gl
Oh really Shintai I heard they get really HOT for people ?
I always heard Ivy gets hotter then Sandy.. hmmmmmm maybe 5 percent faster @ same OC 4.6Ghz... gl
I was just waiting for somebody to state this.
We know what he means. It doesn't need corrected in every ivy thread as it just hijacks the thread. Bottom line is Temps are harder to control compared to Sandy.
My grandma is 92 and has Dementia and doesn't dance much.
Ivy Bridge, hotter than the sun:Oh really Shintai I heard they get really HOT for people ?
An overclocked Ivy Bridge supernova...hot hot hot!!
Ivy Bridge core meltdown:
