I bought two sticks of this memory from Outpost, and, it works in the Soyo 1700xp combo I bought from the same company. I'm going to try it in the ECS I have in my other system. I'm sure it will work, but, not positive.
I ordered two of these last Friday and rec'd yesterday (2 day delivery). Excellent service but I am less than pleased with the memory. I rec'd two different brands and different memory configs.
One uses "Hynix" RAM chips and is a double sided DIMM with 8 chips per side.
The other is uses "Lei" RAM chips and is a single sided DIMM with 8 chips. There is a "Legacy Electronics, Inc." sticker on the DIMM . Printed on each RAM chip is the following:
Lei
LED32808TA-7.5
0206 (comment - probably the lot number) 32Mx8 SDRAM-8-T
Both DIMMS are being sold as DDR 256MB 2100 32X64 266MHz Unbuffered.
I am considering returning it to get two matched pairs. Should I be concerned?
should be nanya branded chips...i just bought some from frys...it is stable but i am not about overclockability...my computer crashes at 140 fsb or gives blue screen errors. not sure if it ram related.
