Those 27'' Korean IPS monitors (Catleap, Achieva) seem like a great deal at a little over $300. It uses the same LG panel used in the $800+ Dell correct?
In about 3 months, Asus will be releasing new 2560 x 1440 IPS monitors, shown in Anand's video here:
http://www.youtube.com/watch?feature=player_embedded&v=TOrUyVbNDO4
Starting at the 18:50 mark.
Just to clarify... so I need two DVI connected to one 2560x1440 monitor or just one DVI would have enough bandwidth for it?
I know one High Speed HDMI cable to a HDMI 1.4a port does...
I had a 2560x1440 monitor. It was nice but I had to return it and go back to 1920x1200. My old eyes could not take the tiny font size. And at that res my games were really struggling and I had to turn most eye candy off.
The cheapest ones have only DVI-D connectors and no scalers, so the only way to hook up a laptop or console would be to set it to 720p, since that requires no scaling being an exact multiple of 1440p.
The more expensive ones for like $480 (Catleap Multi, etc.) come with VGA and HDMI connectors and have built-in scalers so you can use other resolutions such as 1080p, though frankly that will probably look uglier than 720p anyway due to outputs not matching up with physical LCD pixels.
Also, you can ask a merchant directly if a panel supports 1.4a or what.
So if the IPS 2560x1440 has one DVI connector to my GTX 570 or GTX 680 the monitor will effectively display 2560x1440? I'm just confused because you or someone said two DVI connectors to one IPS display...
I never said such a thing and I don't think such a thing even exists.
http://www.playtool.com/pages/dvicompat/dvi.html (scroll down to see DVI comparisons)
If you have a high-performance card you will be fine. If you do order one, just use the Dual Link DVI-D cable they include in the box, as not all DVI-D cables are Dual Link. Hook it up between the monitor and your GX570 or 680. One monitor, one cable, one connector on your card. You may need to use your older monitor's 110V power cord to use with their included power brick, though, as they ship power cords intended for 220V devices, IIRC.
