TheCheeseling
but I can't get the money to buy in one lump sum D:
ok, i'll post the pictures here if the thread doesn't get closed.
it might be in half a year through... I have it set up so I buy one part every 2 weeks.
I'll post pictures every time I get a new part... i'm going to assemble it as I go.
the most I can get is $1000 per month... so I can push 2 months in.... would that work?
If the output material is vital I would build around a machine that uses ECC memory
I keep saying this: you need Windows 8 Pro to use more than 16GB of RAM.
When you have enough RAM, you're fine. When you don't, an SSD helps but it's not the same. 3D modeling is one of those things that needs a lot of RAM.
I generally agree with Sleepingforest on the PSU and the cooler, although the 3930K can draw an awful lot of power, especially overclocked. I'd suggest keeping the PSU and looking for an AMD 7970 instead of the nVidia card. If you're using Adobe CS6 it can use it as well as it could use the 670.
we'll i'm going to be using the RAM for rendering, 3dwork, game servers, RAMdisks, and maybe a lot of that stuff at the same time... I'm going to be rendering multiple scenes at the same time by using three different 3d programs. I think i'll just stick with the 64Gbs
