However, most power supplies have a switch on them, which allows you to use 115 or 230 V. Just change the switch over to the correct position.
If the power supply doesn't have a switch, then you need to change the power supply.
If he is bringing a monitor then you need to check that the monitor is compatible with 115 V,
