AMD 2100 xp OEM Tbred is in stock again. & price drop too $100
http://www.newegg.com/app/viewproduct.asp?DEPA=&submit=Go&description=19%2D103%2D370
Originally posted by: EXman
What is the OEM warranties???
and the 2100+ thoroughbred the same as the AXDA 1700+ and 1800+ that some people are getting the same results as the 2100+'s
Originally posted by: MichaelD
Well, I am at 200MHz (11.5x200=2300 even!)PIC (BTW, I've no idea why the pictures look so crappy once I post them..they look fine on my screen)
But all is not well. All SANDRA tests rock. 3DMARK goes w/o a hitch, but P95 keeps crashing.I'm currenlty at 2.77v memory at 1.8v CPU.
If you remember correctly, When I was at 12x185 all I needed was 1.650v to be stable. Now, my multi is lower and CPU speed is actually 30MHz less (negligible, I guess) so why is P95 still erroring? it errors out only about two minutes into the test.
What voltage should I up next? My timings are CAS2, 2-3-4.
Originally posted by: BigJ2078
Did I mention I have 2 of these Athlon XP 2100+ AIUHB chips sitting on my desk in front of me?![]()
EDIT: About to install one of 'em, wish me luck![]()
Originally posted by: Dug
How high do you think you can get with a slow 80mm fan and an slk-800?
Let me say this right now...a GC68 can't take the heat. Anything over 1.75v = CRASH! Gonna see if I can borrow a friend's
SLK-800. Why oh why did my reservoir have to break :frown:
go to your local home depot and get a electrical box and make it into a resevior . its what i have always used myself
Jen
It's a darn Koolance system, so my options are limited, which is why I'm thinking about buying a totally new setup in a nice big roomy case. That or go back to some nice air cooling.
