2026 Edit: Wanting to make cargo vans with generator as a engine
nakedfrog
63,585
20,032
None, but maybe this project would GIVE me experience.
Just so you know, it would be verging on insanity to take this on as a first project with your level of electrical and mechanical knowledge and no tools or garage.
Reactions: Ken g6
Gizmo j
1,883
510
My uncle has a garage and he used to work at autozone.
sdifox
101,155
18,198
Op is good at thinking up random ideas that make no sense. That is it.
WelshBloke
33,577
11,717
The chances of him actually doing anything to make this happen is slim to zero so the insanity of it is a bit irrelevant really.
Reactions: Ken g6 and lxskllr
Ken g6
Moderator
Dec 11, 1999
16,819
4,804
75
I wanted to be able to go off the grid.
IMHO, needing gasoline means you're not off-grid yet.
A generator takes up space too, and fuel for the generator takes space, and a generator is much heavier, and I already told you to just put solar panels on the roof of the van.
I imagine fixed solar panels on an electric van can get you up to 8 miles of range on a sunny summer day, or about 24 laptop-hours. (Meaning 5 laptops would get ~5 hours worth of solar per day.) More if you could tilt the panels, but I wouldn't attempt this:
You'd probably need at least one 2 Kw/KwH power bank (the two units tend to synchronize) to convert the solar into a form the van would take.
WelshBloke
33,577
11,717
I like that the "solution" being debated is to solve the problem of Gizmo taking a 5 random homeless people that happen to have gameing laptops but no where to charge them into the outback!
WelshBloke
33,577
11,717
And, as far as I know, he doesn't know 5 homeless people with laptops, own a van or generator, know if said imaginary homeless people want to go live in the woods, have a driving license, have the funds to buy van, generator or laptops...
14,064
That or he hopes coworkers at his construction job will want to hang out there instead of, actually working. :p Although it would be kinda cool to have an off grid van build that you can stay overnight in if working a construction job at a site that's far from home, but I doubt they would let you do that. Liability and all that crap.
WelshBloke
33,577
11,717
Stick a Starlink antenna on the van. :D
Actually Starlink has really gone down in price. $70/mo for 100mbps now, that's actually pretty decent considering that's what I pay for 80mbps fibre.
For $70 a month he could pay someone to run an extension lead into their property!
Or he could go the classic route and pay someone to crack open the bottom of a lamp post and steal the electricity from there!
14,064
Good point, all you really need for that is a socket set. Free power! Just test it to make sure it's not 240v or higher as some lights run on higher voltages. That's going to ruin your day when you plug in you laptop. :p
WelshBloke
33,577
11,717
All our stuff runs on 240V!
I'll make a note to use a UK power brick if I'm stealing electric from lamp posts in NA!
lxskllr
60,873
11,217
I might use dialup before I gave Musk money to pollute the skies. That would be a real debate if those were my choices.
Reactions: nakedfrog
Kaido
Feb 14, 2004
52,381
7,636
My friend is a professional astronomer & loathes Starlink:
As of this month, SpaceX has over 9,500 Starlink satellites in orbit, holds authorization for 12,000 so far, and has plans for up to 42,000 total. Light pollution is quickly becoming a real issue:
These multi-exposure images shows streaks from satellites
