While I don't see Toyota as any kind of great innovator (please no hybrid debate; I'll agree that it's innovative if others will agree to not bring it up ;P), I don't think they've been 'cruising on brand name' any moreso that Honda and...well, Honda. I don't don't think anyone else has the 'bulletproof' rep like those two brands. Nissan arguably should, but doesn't seem to.
But those reputations are born out of NOT being cutting edge of innovative. Use what works, and keep using it until change is forced. That's a big part of what has made their cars stand the test of time. While Toyota may be about the most boring carmaker out there, I don't think their reputation for reliability is unfounded...and that's what their buyers are seeking (reliability, that is).
For example, when other manufacturers were moving to engine compartments with electrically controlled parts and near-lack of vacuum lines, Honda still had the ol' spaghetti nest going on. And it kept working. In contrast, the new solenoid-operated parts that others were using were hit and miss, and typically far more expensive to replace than a length of rubber hose or a vacuum motor (which is a chunk of metal or, more commonly, plastic, with a little bit of rubber in the middle).
Anyhow: Recalls for Toyota, like most manufacturers, usually come from tiny engineering oversights. Whereas I've seen a lot of recalls on American cars that involved pretty major failures, Honda/Toyota recalls are, for the most part, something along the lines of 'perform a slight modification to this part' or 'relocate this wiring connector' or whatnot. I accept the stuff as inevitable.
As far as one company being better about recalls than another...meh. For every manufacturer out there, there are people who will say they were treated poorly, they had problems that the dealer could not fix, failures that should've had an extended warranty or recall, ect. Google 'I will never buy from [insert any manufacturer] again,' and you'll get plenty of results. They all have bottom lines, and they will all occasionally do something that is (IMO) shitty and immoral to save a buck.
As far as these recalls- the Lexus one is highly surprising, as loose wiper arms are a very common problem. When I worked for Firestone (uuggghhh), I saw that from every make. Almost every 'wiper inop' complaint was fixed by tightening the nut holding the arm to the wiper transmission. I typically add a split lock washer or a dab of loctite to prevent repeat occurrences. But on the flip side, the recall could be considered UNSURPRISING because it probably pays a tenth an hour of labor and $0 in parts.
I'm curious as to the specifics of the air bag thing. The article mentions an integrated circuit, but I would not be surprised if that's totally incorrect, and it's simply a wiring modification.
edit: missed the Jeep thing. So I'm guessing this is a crash sensor issue?
This is patently false. Honda is one of the most innovative car companies out there. They just don't brag about it and they never collaborate with other companies. Honda is heavily invested in natural gas and fuel cell. They are the only company I know that sell fuel cell vehicles. Honda also has one of the best AWD systems on the road, the SH-AWD.
