Crap Daddy
- May 6, 2011
- 610
- 0
- 0
Intel could make AMD go away completely by releasing a 10W haswell celeron for $67. It would be fast as any AMD
They don't want to. In fact they are as scared as AMD fanboys that AMD might go bust.
They could easily prolong a generation from 1.5 to 3 years and we'll be buying sub-300mm^2 die chips for $500 for years to come. Not fun.
Instead of thinking of it as die size, think about what you are really buying. You're buying transistors. So your measurement should be transistors / $.
Go ahead and chart that out, and you will see massive improvements in price.
Transistors that are cheaper to produce , isnt it....:whiste:
No matter how many times you repeat it, die size is not going to magically become a metric of processor value across different nodes.
But how much cheaper?
But I agree, using diesize/$ is wrong. Using transistors/$ is equally wrong.
We aint far away from where a node shrink however will cost close to the same to produce transistor wise as the previous one.
No matter how much you deny it, the progress in CPUs on the Intel side has slowed down tremendously since historical levels. By now at the very least we should be at 6-core CPU at $325. In the past when AMD was competitive, CPU speed increases on average 2x every 2 to 2.5 years via IPC, clock speeds and more cores. Those cares were passed on to us for free over time as node shrinks allowed more transistors to be shrunk into similar die space and Intel would share the cost savings of node shrinks with us by passing on the extra cores. This way we went from Pentium 4 to Core 2 Duo (2x the cores), and then to C2 Q and 1st generation i7 (2x the cores again). Since that era, Intel fell asleep because they could. If you are happy with 35-45% performance increase in the last 4 years, good for you. If you can't see that Intel has slowed down progress in the CPU space in regard to price/performance, I can't help you. I've been building systems for a long time and after Nehalem, Intel went into hybernation mode. Next year we'll still have quad-core Haswell for $325 or so. Intel gets away charging nearly $100 for HT and a small bump in cache/clocks. This would have never happened if AMD had a competitive product. Quote: Originally Posted by Phynaz Instead of thinking of it as die size, think about what you are really buying. You're buying transistors. So your measurement should be transistors / $. Well really I am neither buying die space not transistors. I am really buying performance. I look at what I had in summer of 2007 and it was Q6600 @ 3.4ghz, then in September 2009 I got Core i7 860 @ 3.9ghz. Since then, CPU speed has hardly improved at a similar price level. Why do I keep focusing on die size? Because a larger die means Intel can add more cores and give us a 6-core CPU $325 (P4 -> C2D -> C2Q). We cannot use the argument that "well it makes no sense to add more cores since very few programs take advantage of more than 4 threads". During Core 2 Duo and Quad era, even less programs used 2-4 threads and yet Intel doubled the number of cores over Pentium 4 and doubled it again over C2D. So lack of software that takes advantage of 6 cores cannot be the primary reason. The primary reason is Intel is milking the consumer because the competition is lacking and they can get away with charging extra $ for K series SKU, extra $ for HT and a small bump in clocks (HT was free during Pentium 4 C era when A64 mopped it). When AMD was competitive, we got IPC, clock speed and core increases and this was very frequent. Transistors by themselves are meaningless if they don't really contribute to extra CPU performance. Enlarging cache or adding a GPU inside Intel CPUs does nothing for me to improve my CPU performance tangibly. If you remove the GPU inside Intel's current CPUs, the amount of die space allocated for CPU centric functions becomes even smaller. Cost wise, nothing is stopping Intel from launching a performance based 6-core Haswell CPU for $325 without a GPU. But they will not do this because there is no need. Instead, they'll probably hold back Haswell-E by nearly a year and continue charging $500+ for a 6-core IVB-E. I will still buy Intel CPUs because I love technology and upgrading for fun, but there is no question in my mind that Intel of today is not the Intel of yesterday because they are not being pushed, not even a little. IVB is actually the perfect example of Intel going towards maximizing margins by moving away from more expensive fluxless solder to the cheap TIM. As Anand noted in his Podcast, IVB was strictly a money making part for Intel. The focus was not really on performance or overclocking. I would even say other than GPU, IVB was the worst refresh in Intel's history. Even Q9550 over Q6600/6700 series was a much better part since on top of added IPC, Q9550 could overclock to 3.8ghz.
Excavator has been taped out already, the first version.
Wow, do you have a link for this? On what node (I'd expect 20nm)? That's incredible if true.Excavator has been taped out already, the first version.
I didn't even know Steamroller was taped out (though that would make sense if it's around a year out from being released).
(To make matters even worse the i7 920 has no integrated graphics, on the laptop chip that 45w tdp is taking in consideration the intel hd 4000 graphics.)
No matter how much you deny it, the progress in CPUs on the Intel side has slowed down tremendously since historical levels.(snip)
I feel like Russian is having one conversation and the rest of the audience is having an entirely different conversation.
And I say this because I totally see where Russian is coming from, but judging by the responses his posts have engendered I don't think people are seeing where Russian is coming from.
Which isn't to say that the other side of the convo isn't right, it is. But one dude is saying "Some apples are red!" and the other side is shouting back "Everyone knows some bananas are yellow!".
Two different conversations, both sides are right, neither realizes they are talking to themselves IMHO.
