Originally posted by: SithSolo1
Originally posted by: bananapeel42
Also, the warranty is instantly voided if you use LC just ONCE. There is a million page thread over at a nissan forum on it, they can tell if you turned it on one time.
So, if in 2 years you have a transmission issue or anything else related to using LC, they can void your warranty based on the ONE time you turned it off.
You need to get your ducks in a row.
Using LC does not void the warranty. Having something break while using LC or within a short time after(week-month) has a high possibly of being denied for warranty coverage.
btw- the thread you are referring to is probably the 79 page thread at nagtroc.org
Also even without LC people are getting stock GT-Rs in the mid-to-high 11s quarter miles. But it doesn't really matter, it isn't a dragster, its a track car.
Here's the offical statement from Nissan North America (from nagtroc)
Released to NAGTROC 10/9/08
The singular thing people need to remember is that using launch control does not void the warranty - The warranty clause regarding the operation of the vehicle with VDC turned off states that Nissan will not cover damage or failures of otherwise covered components, IF it can be determined that the use of launch control led or contributed to the failure. The act of using launch control (which requires turning off the VDC) will not automatically void the vehicle warranty. Simply put, the warranty outlines that failures or damage resulting from things such as misuse, accidents, non-factory modifications, etc. are not covered under the factory warranty.
Further, the warranty states that VDC should only be turned off to help when rocking the vehicle when stuck in mud or snow.
Nissan will not void the entire warranty on any of our cars based on one specific issue of one specific component or system, however, a part or system won?t be covered under warranty if Nissan determines that the failure was as a result of misuse, modifications, etc. (as mentioned above)."
Like you said LC is not really needed. The GTR is already 4wd and a good set of R-comp tires will get that thing moving.
There is probably no way of getting the GTR's tranny to be reliable enough and cheap enough to withstand that much abuse it's going to get from idiot owners.
