Well, I posted this on the dell forums and no answer so I thought I would try you guys over here.
I just got my brand new 2007FP monitor and I set it up on a DVI-D connection for the somewhat better color quality. Anyways, since there is no audoadjust option with this connection I have been trying to configure the monitor so it takes up as much area possible. The only problem is I dont have all the options under "Display Settings" to configure my monitor properly. If you go to http://support.dell.com/support/edocs/m...#Using%20the%20Front%20Panel%20Buttons
and scroll down to the section called "Accessing the Menu System" and scroll even further to the "Display Settings" section you will notice there are options for the following: Wide Mode, H Position, V Position, Sharpness, Zoom, Horizontal Pan, Vertical Pan, Pixel Clock, Phase, Audio Options, Display Info, Display reset and of course Exit Menu and Back...
Now, when I go into this section in my menu the only options listed are Wide Mode, Sharpness, Zoom, Audio Options, Display Info, Display Reset and Back and Exit. Wide Mode, Sharpness, and Zoom are all greyed out and cannot be accessed.
So, how do I go about fixing this and being able to configure my monitor correctly?
Thank you for any help in advance.
