2003 BMW 760Li: Twelve cylinders, 438 horsepower ? and two iDrives
Originally posted by: mAdD INDIAN
Originally posted by: Howard
It needs active air suspension.
madd, I think the RENESIS is supposed to be very smooth also.
RENESIS is a rotary engine, I was talking about V12s.
And yea I figure the Renesis should be smooth since it just spins around an axis 😛
The rotary doesn't really spin evenly around a circular axis the way you think it would, it actually wobbles in an oval.
But you can add counterweights to remove the vibration from a wobble, while you can't add counterweights to remove the vibration from reciprocation as in a piston engine. In a piston engine, half of the rod and the whole piston is not counterbalanced.
True but a V12 and Straight-6 engines are naturally harmonically balanced so there really isn't any need for counter-shafts or anything like that. Smoothness is inherent in their design.
Add boxers to that.
How can an axis be circular? 🙂
