Erm. UD3H is also Crossfire/SLI compatible.
Right, I was just looking at the PCIe speeds, or whatever they are, when being referred to as X16 vs X8...
If it's the newest revision of the board (
rev 1.3) then yes.
Can't seem to find the info on the NCIX page... oh well.
I actually did consider building a server instead of a NAS, but the two do seem to carry different functionality.. though the server can act as a superset of the NAS... For now though, I just wanted something small that can run all the time and run quietly, store media and whatnot... Down the road I may build a server though real estate is quite precious though, so I would have to look into building a very small box that runs silently. Something feasible, I'm sure.
As to the actual suggestion, I will need to look up a couple of your TLAs
🙂 It does sound like a much more techy solution to what I had in mind, and sounds kind of fun...
As per your part suggestions, I actually made the order already, as seen in the quote below, although the actual prices are more than what I stated for the mobo, cpu, ram, case and heatsink, because I missed out on the good deals.
Funny enough, I did get the very same monitors you mentioned, so I hope this means they were a good buy. I know even less about monitors than I do about the rest of the hardware so..
😛 Different SSD suggested by lehtv, although same size as you mentioned. As to why this one was a better choice than Intel, I'm not quite sure... my guess is it has something to do with the controller, but I haven't looked into it yet...
Case -
Antec 1100 $80
Mobo - Z68X-UD3H +
CPU - i5 2500k +
RAM - 8GB Vengeance $310
Heatsink -
Corsair H60 $30
SSD - [FONT=Verdana, Arial, Helvetica, sans-serif]
Crucial M4 SSD Micron C400 128GB[/FONT] $200
HDD - 2TB Caviar Black $180
Monitors - 2x Dell Ultrasharp U2312HM $400
PSU - XFX 750W PRO750W $60
Unrelated
USB Flash drive 32GB $25
Keyboard / mouse $9
Corsair Gaming Audio Series CA-HS1A Headset - $30
BTW, if I was going back to CS these days, I'd buy a nice business laptop
I do have a very cheap laptop (salvaged Presario x1000), which I intend to replace down the road... My intention was to get something that doubles as a laptop/tablet, mainly for the purposes of taking notes in class and being able to do some light work. This probably means I can be quite cheap on it... I see people spending well into $1-2k on "gaming" laptops, I don't quite understand the purpose of them, at least no purpose for someone in my position.
Is this $2000 the entirety of your money
Nope... It was, what I thought to be a fairly generous upper bound for spending on a desktop... I still intend to replace the laptop / tablet as mentioned above, get a new smartphone, and possibly a server as you described.
The desktop just seemed like the highest priority item in the list...
