For me, I really like the plug 'n' play aspect that Apple products have. That usually carries over to OS X. Everything just seems to work.
Even with Windows 7, I still find that it's a hassle to install new services. Troubleshoot how they work, etc... For instance, if you need a web server on your system, it's a simple checkbox. But if you want to dive deeper into it, you have all the Terminal Apache commands that you can use, plus you can edit the server files. On Windows you have to deal with IIS, there isn't a simplified option. If I want to use remote desktop, again.. just a simple checkbox. However, with Windows you have to install UltraVNC, or another system similar to that to get Remote Desktop support.
I'm not saying Windows is bad, but for me, OS X gives me the ease of use, if I want it.. but if I want to get geeky with Terminal hacks, then I have that ability as well. 🙂 To each their own.
