20 questions
I beat it with a key. It was able to guess "car key" after two more questions.
18. I guessed that it was a tire pressure gauge? Wrong.
17. Do you use it at night? No.
16. Do you carry it in your pocket? Yes.
15. Is it a common household object? No.
14. Does it cut? No.
13. Can you use it at school? No.
12. Can it be used to put things together? No.
11. Is it sharp? Depends.
10. Is it something you bring along? Yes.
9. Do most people use this daily? Maybe.
8. Is it a metal? Yes.
7. Is it straight? Yes.
6. Is it colorful? Depends.
5. Is it hard? Yes.
4. Do you use it at work? Sometimes.
3. Do you hold it when you use it? Yes.
2. Is it smaller than a loaf of bread? Yes.
1. It is classified as Other.
I won with Swedish penis enlarger.
Q30. I am guessing that it is a nose hair trimmer?
Right, Wrong, Close
29. I guessed that it was a pipette? Wrong.
28. Do you clean it regularly? Yes.
27. I guessed that it was a syringe? Wrong.
26. Does it have a hole in it? Yes.
25. Can it cheer you up? Irrelevant.
24. Is it straight? Yes.
Does it get wet? Unknown.
23. Was it used over 100 years ago? Doubtful.
Does it contain a liquid? Unknown.
22. Is it hard? Yes.
21. Is it smooth? Usually.
20. I guessed that it was a suppository? Wrong.
19. Is it something you bring along? Sometimes.
18. Is it found in a bathroom? Sometimes.
17. Is it white? Irrelevant.
16. Does it go in your mouth? No.
15. Can you eat it? Irrelevant.
Is it healthy? Unknown.
14. Is it a common household object? No.
13. Do you use it in public? No.
12. Can it affect you (cause an effect to you)? Yes.
11. Is it flexible? No.
10. Is it a synthetic material? Yes.
9. Is it heavier than a pound of butter? No.
8. Can it be stolen? Yes.
7. Is it outside? No.
6. Is it useful? Doubtful.
5. Is it made of metal? Doubtful.
4. Does it bring joy to people? Depends.
3. Is it multicolored? No.
2. Do most people use this daily? Doubtful.
