$20 ceiling fan @ lowe's
Status
Not open for further replies.
tomatom
331
52" ARMITAGE CEILING HUGGER #20776
Hot Deal 5-day Memorial Day Sale
< lots of installation tips on the net >
Setral
868
Shortened URL removed
This link should goto that fan
just go to lowes.com and enter 20776
Admin allisolm
dogchainx
88
I installed this fan about a year and a half ago. Works well enough, no noises, etc. You'll might have to REALLY balance the fan blades. I finally had to tape a bunch of weights on ONE blade to stop the fan from vibrating.
ESQ
173
Instead of taping weights do this first:
Tighten blade holders (with blades firmly attached) to fan with minimum pressure. Tun on fan and let spin for a few minutes. Shut off fan and without touching fan assemblies, tighten down the fan blades. The fan blades find their own place to be balanced. Usually works.
Hawk
2,904
Thanks for the post. Bought and installed today. They had a ton of them. Easy enough...no balancing needed. They also have a bunch of ceiling lights (no fan) for $13-30, some on clearance and some on sale.
Status
