9" Pie Crust
1 1/2 cups flour
1/4 teaspoon salt
1/2 cup of shortening
3-4 tablespoons of cold water
Mix the flour and salt. Cut in the shortening. Combine lightly until coarse meal. Sprinkle with water a tablespoon at a time. Mix lightly with a fork using only enough water so that the pastry holds together when press in to a ball. Roll the ball of pie crust two inches bigger than the pie pan.
Pumpkin Puree(makes 2 1/2 cups)
2 pounds of cooking pumpkin, in large chunks with skin on.
Place the pumpkin pieces into a steamer rack over boiling water in a large pan, cover and steam for 30-45 minutes. Check after 30 minutes. Remove when the interior of the pumpkin is soft. Scrape the pulp pumpkin pulp from the skin. Place the pulp in a bowl and whip with and electric beater.
Pumpkin Pie
Pie crust
1 cup sugar
1/2 teaspoon of salt
1 1/2 teaspoons of ground cinnamon
1/2 teaspoon of ground ginger
1/2 teaspoon of ground cloves
1 1/2 cups of cooked pumpkin puree
1 1/2 cups of evaporated milk
1/2 cup milk
2 eggs slightly beaten
Preheat the oven to 425. Place the pie crust in the pie pan. Mix sugar, cinnamon, ginger, and cloves in a small bowl. In a large bowl beat the two eggs, and mix in the pumpking puree. Mix the sugar mixture into the pumpkin mixture. Mix in the milk. Gradually mix in the evaporated milk. Blend well. Put the pumpkin mixture into the pie crust. Bake for 10 minutes at 425. Lower heat to 300, bake for 45 minutes or until done.
9" two crust, pie crust
2 1/2 cups of flour
1/2 teaspoon salt
3/4 cups of shortening
6-7 tablespoons of cold water
Apple Pie
Two crust pie crust
1 cup sugar
1 teaspoon of ground cinnamon
1/2 teaspoon of ground nutmeg
1 1/2 tablesppons of flour
6-8 large tart apples
2 tablespoons of butter
Prehea the oven to 425. Place one of the pie crusts into the pie pan. Mix the sugar, salt, cinnamon, nutmeg, and flour in a large bowl. Peel, core, and slice the apples. Toss the sliced apples into the sugar mixture, coating the apple slices well. Pile the apple slices into the pie pan, and dot with butter. Drape the second pie crust onto the pie. Crimp the edges and cut several vents on the top. Bake for 10 minutes at 425. Lower the oven to 350 and bake for 30-40 minutes, or until done(when the apples are tender.
9" Pie Crust
1 1/2 cups flour
1/4 teaspoon salt
Pecan Pie
9" Pie crust
3 eggs
1 cup dark corn syrup
1/2 cup dark brown sugar
4 tablespoons of butter, melted
1 teaspoon of vanilla
1 1/4 cups of pecan halves or coarsely chopped pecans
Preheat oven to 425. Place the pie crust into the pie pan, set aside. Beat the eggs in a bowl with a fork, until the yokes and egg whites are blended. Add the corn syrup, brown sugar, melted butter, and vanilla. Blend well. Stir in the pecans, then pour the mixture into the pie pan. Bake for 15 minutes at 425. Lower the oven to 350 and continue balking for another 15-20 minutes. DO NOT OVER COOK. Let the pie cool before serving.
Also a suggestion. Cook almost everything the day before, or theres now way in hell you will be able to do it. Then just heat everything up on Thanksgiving. The pies will stay fresh for 2-3 days, so you could make them 2 days before thanksgiving, and then do the sides, as well as the chickens the day before, and then cook the two turkeys on Thanksgiving morning. Or alternatively cook two if the chickens and one of the turkies the day before, carve them all and store them in the, and then the other two chickens and the remaining turkey the morning of Thankgiving.
1 1/2 cups flour
1/4 teaspoon salt
Pumpkin Pie
Pie crust
1 cup sugar
1/2 cup milk
2 1/2 cups of flour
1/2 teaspoon salt
Apple Pie
Two crust pie crust
1 cup sugar
9" Pie Crust
1 1/2 cups flour
1/4 teaspoon salt
Pecan Pie
9" Pie crust
3 eggs
