2-port video card for OLED display and AVR
TOT111
Is there a video card with 2 HDMI connections
One connection - to the HDDTS receiver - Hear Sound 7.1
Second connection - to the OLED screen
(maybe a DP1.4 to the receiver)
Most GPUs have only one HDMI port, but you can usually use an adapter on a DVI port or a DisplayPort to get a second HDMI port.
thank you
but what do I directed in the card? to
Send HD sound to the AVR (DP )
and HDMI to the TV?
does the adapter need to support HDCP 2.2?
No one will be able to help you unless you provide us with more information about your setup. What are your computer details, what display are you using, what receiver/AVR are you using?
While you can connect 2 HDMI devices to a video card, the bigger problem at play will be that your AVR must be seen by the computer as a display. Video cards are not designed to output audio-only.
Is there a reason you're avoiding connecting the TV to the HDMI output from the receiver? 4k TV with no HDMI 2.0 support on AVR perhaps? That would be the easiest solution of course.
Agree with @NCIXGreg that you should be trying to connect directly through the receiver which will then pass the video signal on to the TV.
If for some technical reason you can't do that, you may also be able to connect directly to the TV and use ARC (Audio Return Channel) to pass the audio back to the receiver.
ARC from my lg oled to the receiver seems to be limited to 2ch when the tv is connected to the PC.
The windows speaker configuration limits me to stereo.
I have a 4k receiver coming tomorrow so I didn't bother to see if there's a way around that.
There are apparently A LOT of hardware particulars between all 3 components and it's not consistent across devices/manufacturers/standards et al.
I did some reading here, but it's frankly more than I personally want to get into at the moment. Still a completely valid point though.
