2 Port SATA Cable to eSATA PCI Slot Bracket: $2.96 AC FS
Status
Not open for further replies.
Pardus
8,197
21
$3.29@dinodirect - coupon code DINOGIFTCARD = $2.96. Free shipping.
What you are viewing is a 2 Port SATA Cable to eSATA PCI Slot Bracket, great in performance, the SATA to eSATA Bracket will be the best choice for you!The SATA to eSATA Bracket is compatible with Serial ATA specification revision 1.0 and all SATA hot swap applications. The SATA to eSATA Bracket is a storage-interface for connecting host bus adapters (most commonly integrated into laptop computers and desktop motherboards) to mass storage devices (such as hard disk drives and optical drives). Serial ATA host-adapters and devices communicate via a high-speed serial cable. Made of high quality material, the SATA to eSATA Bracket is durable and reliable for long time use!Great item for you, do not miss it!
VirtualLarry
56,570
10,203
I got a couple of these with my Gigabyte P35-DS3R mobos, as did a friend of mine with an EP45-UD3R board. Pretty handy to have around, esp. if your mobo didn't ship with back-panel eSATA ports.
Don't forget to switch the BIOS setting for the particular controller you have these plugged into, to AHCI mode, to enable hot-plug support.
Macgyversite
1,172
117
They ship from China if I am not mistaken so.......It's gonna take a while and insurance might not be a bad idea.
Status
