Cut a chunk out of each one.
*shrug*
Originally posted by: nevbie
Cut them. Divide each one to two half-ball pieces. Then measure the wall thickness. The one which has thicker wall, is Al.
Originally posted by: silverpig
Originally posted by: Kyanzes
Easy. Over time the aluminum one will start to oxidize. You won't even have to touch the balls to tell them apart.
Edit: assuming the experiment is not time limited.
Aluminum forms a native oxide that is maybe 2-3 nm thick and is transparent...
Priceless!Originally posted by: Modelworks
Originally posted by: Jimmah
Way too much thought you're all putting into this. Easiest thing is to feel the metal, maybe lick it (oddly enough was a test we did in College), hell you could even be simple and smack the two together and see which one marrs.
Or if in a corporate environment, "What does upper management want each one to be ?"
Originally posted by: yh125d
Putting them in water and seeing which hit bottom first should work silverpig, assuming that there is air in the cavity in the center of each, rather than a complete vacuum and that their weight is determined to be the same by measurement in atmosphere. They will have the same weight on a scale as the air inside will have no effect, but as soon as they are put in water, the greater volume of air inside the steel ball should exert a larger buoyant force on the ball, causing it to sink slower than the aluminum. I think. I had two years of physics in high school and that ended last May
Continuing under the assumption that there is air on the interior rather than a vacuum, weighing them both inside a vacuum should result in the steel being lighter. Wait, maybe not on that part - since the air would only make a difference in the weight if it can exert a buoyant force on the ball, which would require the weighing to take place in an environment denser than the air inside. Weighing them in water should also work.
Originally posted by: QuantumPion
You could put both spheres in a nuclear reactor. The neutron flux would activate nickle alloys in the stainless steel, transmuting them to Co-60 which gives off hard gammas. You could then give the spheres to your lab assistant and time how long it takes for him to start puking his guts out from the radiation exposure.
Man, which planet do you come from???
Originally posted by: JTsyo
The way it works in our office is that you find someone that has dealt with the spheres before and ask them.
And let's complicate the things a bit more. What if the steel ball had aluminum interior and the AL ball had steel interior?
Which of the experiments will fail to tell the difference? 😉
Talk.....
Originally posted by: TastesLikeChicken
Use a Rockwell hardness tester on one of the spheres. You'll get a definitive answer that way.
😕Originally posted by: Born2bwire
Is that included with the Rockwell Automation's Retro Encabulator?
