2 new linksys network cards and neither showing LED lights
TheWickedOne
17
Just bought 2 new network cards by linksys and have them both installed with proper drivers, but neither are showing activity and LAN shows cable is disconnected. Whats the problem?
Mike
ScottMac
Moderator<br>Networking<br>Elite member
Mar 19, 2001
5,471
Bad cables?
Did you make 'em or buy 'em? Are the straight-through, or crossover? what are the machines connection to? Switch/Router/Hub, or each other?
If the machines are connection to a switch/hub/router, you need straight-through. If they are connecting to each other, then you need a crossover.
If you made the cables, give up. Go buy some.
FWIW
Scott
TheWickedOne
17
The cable is running directly from one computer to the other. I have two cables and both came with the cards. Have tried them both with no luck. More help?
