thescreensavers
Ok, so I googled and looked up videos but almost all of them are with a pump for a one man brake bleed flush
How exactly do you do it with two people.
You take the bleed cap off, it will expose the bleeder, attach a piece of plastic tube and into a water bottle or a container, basically a place to put the old fluid, open/loosen the bleeder valve, it will start to trickle out.
Ask your friend to push on the brake Pedal and keep pushing it slowly all the way down, while you add more fluid and make sure it stays above the low line in the reservoir.
With your friend still holding the brake down, Cap the reservoir and close the Bleeder Valve and then let go of the brake pedal.
Then you can do it again or go to the next wheel, you do this one wheel at a time right?
Is that all you need to do? Am I missing something?
