SkylineRider
Thanks for coming in. This is my first time building a computer for myself. I wonder if the components I bought are compatible to each other. Would anyone be generous enough to confirm this? By the way...I have an existing Antec 350Watts Power Supply. Is it sufficient enough to support the listed components, or should I buy a new,stronger one? And another thing is that....Which heat sink for the CPU is recommended? Is there any special deal going on, or particular website that I should check out for certain thing?
Thanks in advance!!!
- NZXT Apollo BLACK NP Black SECC Steel Chassis ATX Mid Tower Computer Case
- ASUS A8R32-MVP Deluxe Socket 939 ATI CrossFire Radeon XPRESS 3200 ATX AMD Mobo
- Crucial Technology Ballistix 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Dual Channel Kit
- Kingston HyperX 1GB 184-Pin DDR SDRAM DDR 400 (PC 3200)
- AMD Athlon 64 X2 4400+ Toledo 2.2GHz 2 x 1MB L2 Cache Socket 939 Dual Core
- SAPPHIRE 100176L Radeon X1950PRO 256MB 256-bit GDDR3 PCI Express x16 CrossFire
- Thermaltake Big Typhoon CL-P0114 120mm Cooling Fan with Heatsink
- Thermaltake Purepower W0129RU ATX12V 600 W Power Supply 115/230 V CE, FCC, UL, CUL, TUV certification
-------------- Links ---------------------
Case:
http://www.newegg.com/Product/Product.asp?Item=N82E16811146025
Mobo:
http://www.newegg.com/Product/Product.asp?Item=N82E16813131004
Memory:
http://www.newegg.com/Product/Product.asp?Item=N82E16820148007
http://www.newegg.com/Product/Product.asp?Item=N82E16820134040
CPU:
http://www.newegg.com/Product/Product.asp?Item=N82E16819103542
GPU:
http://www.newegg.com/Product/Product.asp?Item=N82E16814102061
Monitor:
http://www.compusa.com/products/product...tylePro_SDM_S95FRB_19_inch_LCD_Monitor
Heatsink:
http://www.newegg.com/Product/Product.asp?Item=N82E16835106061
PSU:
http://www.newegg.com/Product/Product.asp?Item=N82E16817153042
One thing that I'm concerning now is the Memory brand drifference. Will the Crucial and Kingston work together fine? I checked the CL value and they both are "2.0" . However, the Crucial voltage is at 2.8 while the Kingston's running at 2.6 ? Will this cause any potential problem under normal & overclocking conditions? Please advise...
Thanks in advance.
Case:
Mobo:
Memory:
CPU:
GPU:
Monitor:
Heatsink:
PSU:
Thanks in advance.
