1gig t-bird @ 1.4
copperdude
39
Is it blue or red core? I thought I got lucky with mine 1G working at 1.2G, but yours is really an achievement. Good job!!!
XaznPKdogX
72
Hey nice at getting ur 1 gig at 1.4, both of you.
Where did you get those fans of yours? I'm planning on doing the same if i can.
If you didn't get them online, can you tell me which online store is good to order from?
And off topic, what's a good case to buy if i want to get the kt7a mobo in with enough room for 2 cdroms and 2 hds? Where can i get it?
thx.
pay
1,401
marooned and dingdong what week are your 1ghz chips? Week 01?
Mykex
380
Marooned...
<< The fans on the side of my case are blowing air in but my cpu fan is blowing out towards the 2 fans.. should I reverse that one or should I just leave things the way they are. Thanks again you've been more than helpful >>
This caught my eye the FOP32 should blow down on the HS not suck away and blow out towards the side fans. I think if you turn it around if it is on backwards you will see a temp drop.
VladFrost
113
hmmm... hmmmm thats pretty fast 1.4 what do you know i think its time to go sub zero tempretures for me.
