Originally posted by: Black88GTA
Originally posted by: rezinn
Don't buy that 91' camaro. Buy a newer car that you don't like before you buy a 17-year old car in bad condition that will most likely cost you more than you could ever imagine.
Not necessarily...mechanical parts for third gen F bodies are dirt cheap even when compared to most other domestics, let alone any Asian or Euro car, and the body panels are readily available in decent condition in junkyards. If the OP can do some work himself (or is willing to learn) then that car wouldn't cost much to keep up at all. If it has to go into the shop every time something breaks, then it may get expensive.
I would agree that better ones can be found in that price range. The body damage on the one in question, while repairable, sort of kills it. At minimum , it is going to need a new fender, work done on the rear quarter, and paint. It'll probably also need a hood and other odds and ends to make it right.
OP - your call, but don't feel like you have to settle for some shit Corolla that you'd be miserable in just because you are scared of potential repair costs. I'd keep looking around.
