1959 intercom system
JSt0rm
27,399
3,948
when a secretary buzzes into the office that you have a call do you hear a buzzer type sound and then the secretary on the speakerphone or just the secretary and no buzzer anywhere?
lxskllr
60,926
11,258
It probably varies by system. If it buzzed, I think it would be before the secretary spoke.
Squisher
21,204
66
If I remember correctly, you push on that arm half way to activate the intercom, if you push it all the way down it buzzes.
SKORPI0
18,503
2,430
Soft buzzer/blinking light to inform you of an incoming call.
You decide to answer or not, if not, secretary/phone operator tells caller you're not available/present or busy, asks who it is, phone# for call back or even better ask what the call is for.
index.php
lxskllr
60,926
11,258
That's a beautiful piece of equipment. They don't make things with style anymore. It has to be cheap, and generic :^/
14,084
I think the buzz is just to alert you of the incoming intercom call. That way if you are talking or doing something else it catches your attention so you can listen. Where I work whenever they make an announcement there is always a beep before. Same idea I guess.
JSt0rm
27,399
3,948
so buzz secretary and then you pick up.
No buzz for the actual call waiting for you.
JSt0rm
27,399
3,948
index.php
right ok so there would/could be a soft buzz during the incoming bit
JSt0rm
27,399
3,948
at least my white pants follow cause and effect.
Actually dumb fuck, someone already said that the secretary can call in say the who is on the phone and then have it trigger a buzz and flashing light after they make the transfer, this would cause your dumb ass to pick it up. In the event you don't pick it up the effect would be it would bounce back to the secretary who would then take a number.
Mar 10, 2005
14,647
is the secretary hot?
