apoppin
Originally posted by: zodder
Have you made sure that the molex connector(s) are straight from the PSU and not piggy-backed off another peripheral?
how important is that ... really?
Originally posted by: SC4RF4C3
I think it has something to do with the voltage though it says its 3.0 it only can use cards that are 1.5v which is weird.
that being said is there an easy to tell which cards do 1.5v? is it just cards that can do 4x agp? or is it alot harder?
thing is if my mb isnt .8v compliant then it wouldnt work which I think is the problem I contacted BFG and they assured me that all there cards are both compliant 1.5v and .8v, therefore thats why I am able to use their cards with no problems...
that being said what would be a good power supple for a 7800GS AGP?
ps I took it back to the store they tested with their systems and the power supply I bought and it worked.
I am stumped
my MB says to only use 1.5V cards only even though its 3.o compliant.
1 x AGP slot (8x/4x-AGP 3.0 compliant), supports 1.5v display card only.
http://www.gigabyte.com.tw/Products/Mot...&ProductID=1914&ProductName=GA-K8U-939
On rage3d, they seem to think it's pretty important. My Sapphire 1950 Pro has that stated at least 3 times in the crap that came with it.Originally posted by: apoppin
I tried all that to no avail everything that has been stated to try has been tried and it willl not work simply because its .8v and my MB is only 1.5v compliant.
I just installed a BFG 7800GS and it also works flawless started up no problem.
the visiontek 1950 agp is a .8v only card so therefore it is useless to my system.
sure i did that too ...Originally posted by: Stumps
I think it's pretty much common sense to give any video card with molex connectors, it's own connector straight from the PSU with nothing else attached to the line....
Originally posted by: VirtualLarry
I just picked up a Sapphire X1950GT PCI-E 256MB card, was planning on hooking it up to a molex chain that is powering my 4 SATA HDs and a couple of fans, is that a bad idea? My PSU is a SuperFlower 520W, 18A or 20A on the 12V rail, rest of system is an A64 4000+ OC'ed, 5 HDs total, not much else in there yet.
