19" monitor - what to set the res to?
<< I happen to like 1280x1024, just suits me. >>
I use my optimal settings that my monitors says is good.. 1280x1024x85hz
1400x1050x32bit is the best resolution to run on a 19" monitor. Granted, you have to find some tweaking utilities and stuff to create that custom resolution, but it works perfectly.
I'm running a 21" cornerstone that's recommended to run 1200X1600@85, but I run it at 1024X768@85 becuse I can't get some of the fonts to enlarge to where they're readable in some windows, like the names on different folder tabs that a window might have.
<< 1400x1050x32bit is the best resolution to run on a 19" monitor. Granted, you have to find some tweaking utilities and stuff to create that custom resolution, but it works perfectly.
ditto, not too small, not too big, and good refresh rates. You dont accually need a tweaking utility, just your gfx drivers and notepad!
