The uppsalla run is 42.6 miles. He does it in sub 15 minutes, I believe. 42.6*4 = 170.4 miles. So, if I just crank it a bit harder... Seattle to Portland ain't so unbelievable. (Of course, refueling makes this harder BUT there will be less slowing down because there are a lot of open straights with no need to slow) Btw, it won't take 2 minutes to fill up. You can do it quicker if you just have the 5 gallon bucket on the side of the road... Drain it all in as fast as possible with some kind of speedy way. (Figuring out a way to avoid the air needing to get in from the nozzle part)
