mb
Originally posted by: lazarus000
http://www.newegg.com/Product/Product.a...44358&ATT=Hard+Drives&CMP=OTC-d3alt1me
newegg has same drive
93.00
2.99 shipping
95.99
Thanks!
93.00
2.99 shipping
95.99
Originally posted by: ClimberRich
What's a good moderately priced controller that will do sata Raid 1 or 5?
On the low end I seem to find lots os stuff that has questionable reliability/limited software support for $20 or $30.
On the high end I'm finding lots of $2 or 300 controllers.
Thanks!
wag,Originally posted by: Reiniku
I have 3 of the 300gb flavors of this drive running for nearly 6 months now. Really happy with them and am buying a 4th to possibly run raid 5, or just run them independent.
Originally posted by: Novercalis
everyone flames maxtor.
everyone flames WD
everyone is undecided with Haitchi whatever
we all heard Seagte also failed many time but yet praised..
guys for once I will threadcrap and say STFU...
we all heard peoplle supporting Maxtor aswell
with Haitchi, samsung, WD, Seagate.
its either Noise, failure, Hot or something ya complain about when it comes to HD.
I have acknowledge when searching for realible HD, i seen the good and the bad on all product and concluded there isnt a PERFECT HD out there. plain and simple.
maxtor is still a active HD supplier and it would have went down to hell if those complains were true to a point to hurt thier sales.
nuff said..
Originally posted by: SimMike2
I've had excellent luck with Maxtor drives. They have been more reliable for me than either WD, Seagate, IBM and Hitachi - combined! What has been most disturbing about the failure of these other brands is the lack of warning. With Maxtor, you can usually tell something is going on, which gives you time to backup and maybe swap out the drive for warranty work. WD is notorious for sudden failures. Seagate and IBM (Hitachi now) are famous for hard to get warranty work.
Considering Maxtor drives generally mailfunction from electronic component failure, you are regularely giving NO warning and just a symptom of a) click of death/head sync failure or b) complete controller failure/initialization failure.
Both cases result in irrecoverable data [SNIP]
Actually, in the case of a controller failure, getting your data off is usually as easy as getting the same model drive and slapping on the new PCB board attached to the underside of your HD. And as for the "click of death", this is the easiest thing that a Data Recovery Service can expect. They actually charge a flat fee instead of per MB in most cases I've heard of with this problem.
There is rarely a case of truely "irrecoverable" data when it comes to HDD failure. It's just a mater of if you think your data's worth the price of recovery.
When it comes to HDD failure, if you are really worried about it, buy server Harddrives. They are the true kings of realibility. Very rarely do you hear about a SCSI drive failing them, or having to RMA their WD Raptor. It's not the brand name that makes the biggest difference. It's the quality of the drive. You get what you pay for.
i've never used a seagate drive myself.Originally posted by: Merlin
I have both WD's and Maxtors and Hitachis and Seagates and have had failures from all companies, but none that would be considered above average (except the old IBM 75 GXP's). The MAXLINE III has a 5 year warranty, the 2500JB that I most recently had die that i purchased RETAIL had only a 1 year warranty..
