Originally posted by: ArchAngel777
Originally posted by: Matthias99
A 32" 1360 X 768 has the same image quality as a 42" 1920 X 1080 when within the same relative viewpoint. Because a 42" TV is larger, you will sit back further than one would with a 32", thus, it all equals out in the end.
In terms of image detail, a 1920x1080 display simply has more (real) pixels than a ~1300x768 one and can display a more detailed image without aliasing.
If you sit such that they have equal (apparent) pixel density, the higher-resolution display will be filling up more of your vision (unless there is a dramatic difference in pixel density between the displays). If you are sitting such that each display fills about the same amount of your visual field, the higher-resolution one will have higher (apparent) pixel density. Everything else being equal, higher resolution is better.
If you're looking at a situation where you can't sit further away from the display (ie, you want to put it on your desk and use it as a dedicated computer monitor), it can be a big problem. I agree, though, that if you're going to use it from across the living room... not so much, unless you want to work on high-resolution photos or watch native 1080i/1080p content.
There is theory and then they is reality. The reality is that 30"+ displays for monitors are totally awesome. The reality is that despite being 1280 X 768 and sitting less than 2 feet away, I can surf, game, read and spend pretty much all day on here with no problem. My work LCD is so... unatractive... Yet, it does 1280 X 1024 on its 17" panel, but to tell you the truth, I don't see how anyone would be willing to take a 17" over a 30" in that situation, much less anything else.
Because if you're sitting close to it you don't have to actually move your head to see the other side of the screen?
I don't move my head, I move my eyes.Originally posted by: Roguestar
I respect your opinion, but frankly, I tried a 24" Dell widescreen LCD, and I found it tougher to work with than two 19/20" displays. I was having a hard time dealing with the image extending so far into my peripheral vision.
Maybe I would have adapted if I had kept it longer, but (IMO) at normal 'desk' distance (~2 feet), a monitor much bigger than that would just be unwieldly. You can't focus on the whole screen at once. If you're going for the whole 'immersive gaming' thing, maybe. For desktop work, I'm unconvinced. Definitely try before you buy.
But there's definitely a point where smaller is worse. A 17" LCD would be kind of small (but usable); I wouldn't buy anything smaller than that for desktop use. Dual 19/20" LCDs are IMO the best setup for desktop work (unless you need so much screen area that you want dual 1920x1080 widescreens).
Originally posted by: BigPoppa
I game on my 32" Westinghouse at 1360x768. World of Warcraft is what I play mostly. Building a core2duo rig right now, have all the components purchased except for the 8800GTS, which I'll be ordering today. Haven't played any FPS yet, but WoW is fantastic. I'll probably pull out UT2k4 and the EVGA 8800GTS comes with Dark Messiah, so i'll get back to you on those games.
Originally posted by: n7
I can't understand the desire to have to sit in front of a 32" 1366x768 display
That's a low resolution on a huge screen...way too hard on the eyes, & z0mg, the pixelation would be horrifying.
I don't see stitting halfway across my room to be able to comfortably use my display as being ideal.
24" LCD would be oh so much better IMO.
Get a TV or projector for when you want to watch movies...
That's how i do it.
I have my two 20" LCDs, & i use my projector (roughly 70" picture) for all video content![]()
